[gdal-dev] mosaicking files with partial overlap and binary mask
Patrick Young
patrick.mckendree.young at gmail.com
Thu Jan 28 07:23:33 PST 2021
I do not!
If you want to try it out without building latest yourself and can use
docker, you can snag one of the latest containers here and see if it works
for you:
https://hub.docker.com/r/osgeo/gdal/tags?page=1&ordering=last_updated
Best,
Patrick
On Thu, Jan 28, 2021 at 2:12 AM Daniele Romagnoli <
daniele.romagnoli at geo-solutions.it> wrote:
> Hi Patrick,
> nice!
> Thanks for the feedback.
> Do you have any info about eventual backports to previous versions?
> Regards,
> Daniele
> On Thu, Jan 28, 2021 at 12:02 AM Patrick Young <
> patrick.mckendree.young at gmail.com> wrote:
>> Hi Daniele,
>> Even added this functionality to VRTs just recently, see
>> https://lists.osgeo.org/pipermail/gdal-dev/2020-December/053178.html
>> I think it is slated for GDAL 3.3 but you could always build the bleeding
>> edge.
>> Patrick
>> On Wed, Jan 27, 2021 at 3:50 AM Daniele Romagnoli <
>>> Hi list,
>>> I have some TIFF datasets with partially overlapping edges and embedded
>>> binary masks to keep into account which parts along the edges should be
>>> masked out.
>>> When showing all the images on QGIS it looks good since the binary mask
>>> do its job by making the "black/white" overlapping edge masked out.
>>> Now I need to create a single TIF from all of these images.
>>> I have tried with gdalbuildvrt but it doesn't produce good result.
>>> Checking the doc I saw this:
>>> *If there is some amount of spatial overlapping between files [...]
>>> currently, alpha channel is not taken into account to do alpha compositing
>>> (so a source with alpha=0 appearing on top of another source will override
>>> is content). This might be changed in later versions. *
>>> So I think it's expected and I have switched to gdal_merge.py.
>>> It works better since it does alpha compositing but it looks like the
>>> result doesn't preserve the binary mask which I still need since I have M
>>> groups of N files which I need to process in 2 passes:
>>> - the inner group of N files get merged using the binary mask to a
>>> bigger file.
>>> - all the M bigger files get mosaicked again to a single huge file.
>>> I will spend some more time in testing different attempts.
>>> In the meantime, do you have any suggestion or past experience on how to
>>> deal with that?
>>> Side note: I have vague memory of gdal_merge being somehow memory
>>> bounded, throwing memory allocation errors when trying to compose big
>>> images. This is why in the past I was using gdalbuildvrt to do composition
>>> (without overlapping).
>>> Thanks in advance.
>>> Regards,
>>> Daniele
>>> Regards,
>>> Daniele Romagnoli
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Daniele Romagnoli
>>> Senior Software Engineer
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A
>>> 55054 Massarosa (LU)
>>> Italy
>>> phone: +39 0584 962313
>>> fax: +39 0584 1660272
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Regards,
> Daniele Romagnoli
> GeoSolutions S.A.S.
> Italy
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210128/304b47e0/attachment-0001.html>
