[gdal-dev] Motion: remove and deprecate a few drivers
Javier Jimenez Shaw
j1 at jimenezshaw.com
Thu Mar 4 00:41:22 PST 2021
+1
(using a docker image to convert any of those removed formats if you find a
file at the bottom of you cellar in the far future is a great alternative.
Thanks Even)
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Wed, 3 Mar 2021 at 19:49, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> Following the discussions of past weeks, I motion to:
> - remove the vector drivers BNA, AeronavFAA, HTF, OpenAir, SEGUKOOA,
> SEGY, SUA, XPlane and raster drivers BPG, E00GRID, EPSILON,
> IGNFHeightASCIIGrid, NTv1. They have all been authored by myself and I'm
> not aware of them having been much used or being still in use.
> Implemented in https://github.com/OSGeo/gdal/pull/3373. They (driver
> code, doc and tests) have been moved to the
> https://github.com/OSGeo/gdal-extra-drivers
> - deprecate the raster drivers DODS, FIT, GS7BG, GSAG, GSBG, JDEM,
> JPEG2000, JPEGLS, MG4LIDAR,
> GMT, DOQ1, DOQ2, FUJIBAS, IDA, LAN, MFF, NDF, SDTS, SGI, XPM, ZMAP
> and vector driver ARCGEN, ArcObjects, CLOUDANT, COUCHDB, DB2, DODS, FME,
> GEOMEDIA, GTM, INGRES, MONGODB, REC, SDTDS, TIGER, WALK. They will now
> be disabled
> at runtime by default, unless the
> GDAL_ENABLE_DEPRECATED_DRIVER_{drivername}
> configuration option is set to YES, and will be removed in GDAL 3.5.
> Implemented in https://github.com/OSGeo/gdal/pull/3505
> Starting with my +1
> Even
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210304/62c61cc1/attachment-0001.html>
