[gdal-dev] Is it possible to switch warnings off?
Even Rouault even.rouault at spatialys.com
Sun Mar 7 14:15:13 PST 2021
Joaquim,
I suspect you are not testing with the same GDAL version with your
gdalinfo shell invokation or within julia.
With the C API, you can shut down warnings and errors with
CPLPushErrorHandler(CPLQuietErrorHandler);
CPLPopErrorHandler();
You can install a custom error handler that filters only some category
of events. See
https://gdal.org/api/cpl.html?highlight=cplpusherrorhandler#_CPPv419CPLPushErrorHandler15CPLErrorHandler
Even
Le 07/03/2021 à 21:42, Joaquim Manuel Freire Luís a écrit :
> Hi,
> I have this strange case where some warnings come from don’t know where.
> From a shell command (cmd but it doesn’t matter) all fine
> gdalinfo AQUA_MODIS.20020717T135006.L2.SST.nc
> Driver: netCDF/Network Common Data Format
> Files: AQUA_MODIS.20020717T135006.L2.SST.nc
> Size is 512, 512
> Metadata:
> /navigation_data/NC_GLOBAL#gringpointlatitude={28.923635,25.633446,42.81229,46.942131}
> However, the same but this time called from Julia that wraps calls to
> options = GDALInfoOptionsNew(options, C_NULL)
> result = GDALInfo(ds.ptr, options)
>                GDALInfoOptionsFree(options)
> I get these warnings
> julia> println(gdalinfo("AQUA_MODIS.20020717T135006.L2.SST.nc"))
> Warning 1: The dataset has several variables that could be identified
> as vector fields, but not all share the same primary dimension.
> Consequently they will be ignored.
> Size is 512, 512
> Metadata:
> Also get several of these in other commands
> Warning 1: dimension #1 (pixels_per_line) is not a Longitude/X dimension.
> Warning 1: dimension #0 (number_of_lines) is not a Latitude/Y dimension.
> Is there anyway to shut up this warnings, or warnings in general?
> Thanks
> Joaquim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210307/aa30b338/attachment-0001.html>
