[gdal-dev] More info on gdalwarp resampling methods?
Even Rouault
even.rouault at spatialys.com
Tue Mar 30 23:38:41 PDT 2021
Matt,
(leaving out a bit your general question) The below looks is an error
unrelated to whatever resampling method you apply. This is completely
unfamiliar though. Do you build GDAL yourself ? Did you disable
threading at build time ? Or maybe you're enabling threading with a huge
number of threads ? Does that happen all the time ?
Even
> Background: I’m getting error messages when trying to use some of the
> methods with 16bit imagery and I don’t know if I’m seeing a gdal bug,
> a data bug, or just “you can’t use that method with this raster type”.
> ERROR 1: Failed to acquire WarpMutex in WarpRegion().
> Thanks!
> *Matt Wilkie*
> Geomatics Analyst
> Environment | Technology, Innovation and Mapping
> T 867-667-8133 | _Yukon.ca <http://yukon.ca/>_
> /Hours: 08:30-16:30, Tue-Wed: Office, Thu-Fri: Remote./
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210331/0a7a7bdc/attachment.html>
