[gdal-dev] More info on gdalwarp resampling methods?
Matt.Wilkie at yukon.ca Matt.Wilkie at yukon.ca
Wed Mar 31 09:46:46 PDT 2021
It looks like my knack for stumbling into weird edge cases is still alive and well! Whee.
I'm using gdal from Qgis v3.16 on Windows.
I was trying the (mode,max,min,med) resampling methods and get the error reliably with `mode`. I thought I got it on a 2nd or 3rd method also but didn't repeat that this morning. I've been playing with GDAL_CACHEMAX and -wm numbers so that might be a factor.
Working directory is a local SSD drive and there is 32 GB physical memory, generally 50% or more free. Free drive space is on the low end, 10 GB on C: and 7 GB on D:, where the working folder is.
gdalwarp ^
--config GDAL_CACHEMAX 4096 ^
-wm 512 ^
-multi ^
-co TILED=YES ^
-co COMPRESS=ZSTD ^
-t_srs EPSG:3579 ^
-r mode ^
-co predictor=2 ^
tri_mergedDEM_clipped_16bit.tif ^
tri_mergedDEM_clipped_16bit_ytalb-rs-mode.tif
Console:
$ gdalwarp --config GDAL_CACHEMAX 4096 -wm 512 -multi -co TILED=YES -co COMPRESS=ZSTD -t_srs EPSG:3579 -r mode -co predictor=2 tri_mergedDEM_clipped_16bit.tif tri_mergedDEM_clipped_16bit_ytalb-rs-mode.tif
Creating output file that is 89772P x 73148L.
Processing tri_mergedDEM_clipped_16bit.tif [1/1] : 0Using internal nodata values (e.g. -99) for image tri_mergedDEM_clipped_16bit.tif.
Copying nodata values from source tri_mergedDEM_clipped_16bit.tif to destination tri_mergedDEM_clipped_16bit_ytalb-rs-mode.tif.
..ERROR 1: Failed to acquire WarpMutex in WarpRegion().
The info report for source image is attached, which can be downloaded from https://sft.gov.yk.ca/link/gV2K9F4PyH1PTJLQH8fy99  until April 14. (500mb).
-Matt
Sent: March 30, 2021 11:39 PM
To: Matt.Wilkie <Matt.Wilkie at yukon.ca>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] More info on gdalwarp resampling methods?
Matt,
(leaving out a bit your general question) The below looks is an error unrelated to whatever resampling method you apply. This is completely unfamiliar though. Do you build GDAL yourself ? Did you disable threading at build time ? Or maybe you're enabling threading with a huge number of threads ? Does that happen all the time ?
Even
Background: I'm getting error messages when trying to use some of the methods with 16bit imagery and I don't know if I'm seeing a gdal bug, a data bug, or just "you can't use that method with this raster type".
Thanks!
Matt Wilkie
Geomatics Analyst
Environment | Technology, Innovation and Mapping
T 867-667-8133 | Yukon.ca<https://imsva91-ctp.trendmicro.com:443/wis/clicktime/v1/query?url=http%3a%2f%2fyukon.ca&umid=AC1EC954-BECF-5E05-B6CB-AE995C90C7E2&auth=c132af8ee7c9d1278d61a701569070a095ce962e-90d4f63b9d26941043d059b2a373176c1c6f200f>
Hours: 08:30-16:30, Tue-Wed: Office, Thu-Fri: Remote.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com<https://imsva91-ctp.trendmicro.com:443/wis/clicktime/v1/query?url=http%3a%2f%2fwww.spatialys.com&umid=AC1EC954-BECF-5E05-B6CB-AE995C90C7E2&auth=c132af8ee7c9d1278d61a701569070a095ce962e-76fdcd2f1d6f12f56ce5a5d39e4c63f2993393ad>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210331/8dbf7f1f/attachment-0001.html>
Type: application/octet-stream
Desc: tri_mergedDEM_clipped_16bit.tif.info
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210331/8dbf7f1f/attachment-0001.obj>
