[gdal-dev] gdal2tiles.py - next step
Clay, Bruce
bclay at infoscitex.com
Mon Nov 8 06:37:06 PST 2021
I am trying to add WMTS / TMS to our current WMS mapserver. I have some map tiles generated by gdal2tiles.py that appear to be valid. There is a tilemapresource.xml file in the root of each tile set.
I am not sure the correct forum to ask this question but how do I configure mapserver to serve one of these tile sets when there is not a corresponding original source to put in the mapserver configuration file? I added the mapcache.xml file as follows
<cache name="bm_200401" type = "disk">
<base>H:/ms4w/cache/BlueMarbleTiles_200401</base>
</cache>
<tileset name="bluemarble200401">
<source>bluemarble_src</source>
<cache>bm_200401</cache>
<metatile>5 5</metatile>
<format>PNG</format>
<grid>WGS84</grid>
<metadata>
<title>Blue Marble 200401</title>
<abstract>Blue Marble - January 2004 - tiles</abstract>
<keywords>
<keyword>Blue Marble</keyword>
<keyword>tiles</keyword>
</keywords>
</metadata>
</tileset>
<grid>WGS84</grid>
<metadata>
<keywords>
</keywords>
</metadata>
</tileset>
When I select the tile set in QGIS using
http://localhost/mapcache/wmts?service=wmts&request=getcapabilities&version=1.0.0
All of the layers show as available layers but the only ones that show on the map are the ones that have an entry in the WMS map file.
>From my understanding the tilemapresource.xml file generate by gdal2tiles.py specifies the zoom levels and resolution but it is not specified in any of the configuration files.
Any suggestions would be greatly appreciated.
Bruce
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211108/fd372442/attachment.html>
