[gdal-dev] PGCLIENTENCODING in ogr2ogr (and QGIS)
matteo
matteo.ghetta at gmail.com
Mon Nov 29 08:51:47 PST 2021
Hi all,
I'm trying to run a command with the GdalUtils.runGdal utility of QGIS
but I get some troubles because of the encoding.
Basically I need to set the encoding to PGCLIENTENCODING=LATIN1. If I
call it in a console, no problem at all (of course :) ). Wondering if I
can set the encoding also within QGIS (that is basically via the ogr2ogr
command).
I know that this is a more QGIS question, but QGIS is calling ogr2ogr,
so I think if there is a ogr2ogr way to do that then also within QGIS
should be possible.
Cheers and thanks for any ideas!
Matteo
