[gdal-dev] ogr2ogr and WFS 2
Hernán De Angelis
variablestarlight at gmail.com
Tue Nov 30 00:54:03 PST 2021
Sorry, in the message below I meant one needs to explicitly specify
OGR_WFS_PAGING_ALLOWED YES, with a suitable OGR_WFS_PAGE_SIZE.
Den 2021-11-30 kl. 09:34, skrev Hernán De Angelis:
> Thank you, Jukka. I did that and worked. I also had another case where
> it is important to get this right. It is when the total number of
> features exposed by the service exceeds the maximum number of features
> allowed to be fetched in one request (CountDefault). In this case it
> is also important to set the paging to NO, in addition with an
> adequate OGR_WFS_PAGE_SIZE so that the layer can be downloaded
> entirely, in several pages, without hitting the limit.
> Best
> Hernán
> Den 2021-11-30 kl. 08:59, skrev Rahkonen Jukka (MML):
>> Hi,
>> There is something about WFS 2 and paging in
>> https://gdal.org/drivers/vector/wfs.html
>> “Paging with WFS 2.0
>> The WFS driver will automatically detect if server supports paging,
>> when requesting a WFS 2.0 server. The page size (number of features
>> fetched in a single request) is limited to 100 by default when not
>> declared by the server. It can be changed by setting the
>> OGR_WFS_PAGE_SIZE configuration option, or by specifying COUNT as a
>> query parameter in the URL of the connection string.
>> If only the N first features must be downloaded and paging through
>> the whole layer is not desirable, the OGR_WFS_PAGING_ALLOWED
>> configuration option should be set to OFF.”
>> So by default normally GDAL goes to paging mode that makes it
>> possible to read the whole featuretype, possibly restricted with BBOX
>> or other filters but it should be possible to disable paging with
>> --config OGR_WFS_PAGING_ALLOWED OFF. I would try that.
>> -Jukka Rahkonen-
>> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
>> *Hernán De Angelis
>> *Lähetetty:* maanantai 29. marraskuuta 2021 12.43
>> *Vastaanottaja:* gdal-dev at lists.osgeo.org
>> *Aihe:* [gdal-dev] ogr2ogr and WFS 2
>> Dear all
>> I seem to have problems understanding how ogr2ogr interacts with WFS
>> and hope someone would be able to clarify.
>> I have this WFS:
>> https://stationsregister.miljodatasamverkan.se/geoserver/stationsregistret/wfs?
>> The capabilities document states that it supports WFS 1.0.0, 1.1.0
>> and 2.0.0.
>> If I do:
>> ogr2ogr -f GPKG test.gpkg
>> "WFS:https://stationsregister.miljodatasamverkan.se/geoserver/stationsregistret/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=stationsregistret:active_site&MAXFEATURES=100
>> <https://stationsregister.miljodatasamverkan.se/geoserver/stationsregistret/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=stationsregistret:active_site&MAXFEATURES=100>"
>> I get a small and nice GPKG file very fast.
>> But if I do:
>> "WFS:https://stationsregister.miljodatasamverkan.se/geoserver/stationsregistret/wfs?SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAMES=stationsregistret:active_site&COUNT=100
>> <https://stationsregister.miljodatasamverkan.se/geoserver/stationsregistret/wfs?SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAMES=stationsregistret:active_site&COUNT=100>"
>> It downloads the whole layer.
>> This behaviour can be seriously impractical for services exposing a
>> large number of features.
>> Pay attention that if I do:
>> curl
>> "https://stationsregister.miljodatasamverkan.se/geoserver/stationsregistret/wfs?SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAMES=stationsregistret:active_site&COUNT=100"
>> it retrieves a short document fast with just 100 features. The same
>> of course if I invoke the service using WFS 1.0.0 or 1.1.0.
>> What is going on here? Is it me that I misunderstood something about
>> how ogr2ogr is supposed to interact with WFS services?
>> Using GDAL 3.4.0, released 2021/11/04. But the same behaviour was
>> observed in 3.3.2.
>> Thanks in advance for any clarification
>> Hernán
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211130/a9a8b896/attachment-0001.html>
