[gdal-dev] RFC 84: Migrating build systems to CMake
Andrew C Aitchison andrew at aitchison.me.uk
Tue Oct 5 06:46:12 PDT 2021
On Mon, 4 Oct 2021, Even Rouault wrote:
> Please find at https://github.com/OSGeo/gdal/pull/4590 a RFC that proposes:
> - to develop a CMake build system, officially integrated in the source tree.
> - and remove the current GNU makefiles and nmake build systems, when the
> CMake build system has matured enough and reached feature parity.
I guess that means that an option for builders to configuring drivers as
 	builtin / plugin / not included
is out of scope (not present in current system).
If someone is going through all the drivers it might make sense to
do this at the same time, or at least design things so that
only a central change is needed to enable it for all drivers ?
Andrew C. Aitchison					Kendal, UK
