[gdal-dev] WMTS error with gdal2.4.4
Elena Ruiz eruiz at aplitop.com
Thu Sep 9 09:03:57 PDT 2021
Hello, I have two versions of GDAL 2.4.4 with the dll gdal204.dll dated 2020/01/08, but one is 17.4Mb and the other 20.3 Mb, with Gdal.VersionInfo I get the version of both files and is the same, but they give different results with the following command:
DLL gdal204.dll (20,3 MB)
>gdalinfo "WMTS:http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS&username=&password=,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:25830"
ERROR 1: latitude or longitude exceeded limits
Driver: WMTS/OGC Web Map Tile Service
Files: none associated
Size is 20616192, 28663296
Coordinate System is:
PROJCS["ETRS89 / UTM zone 30N",
    GEOGCS["ETRS89",
        DATUM["European_Terrestrial_Reference_System_1989",
            SPHEROID["GRS 1980",6378137,298.257222101,
                AUTHORITY["EPSG","7019"]],
            TOWGS84[0,0,0,0,0,0,0],
            AUTHORITY["EPSG","6258"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4258"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-3],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH],
    AUTHORITY["EPSG","25830"]]
Origin = (-1968157.094999999972060,7271532.000000000000000)
Pixel Size = (0.149291070899963,-0.149291070899963)
Metadata:
  ABSTRACT=Imagen de sat├®lite Sentinel2 a escalas menores de 1:70.000 y las ortofotograf├¡as PNOA de m├íxima actualidad para escalas mayores, para toda Espa├▒a. Las teselas se pregeneran en formato JPEG y hasta el nivel 19 (correspondiente con una escala aproximada 1:1.000) en el Sistema de Referencia por Coordenadas WGS84 Web Mercator (EPSG:3857).
  TITLE=Im├ígenes de sat├®lite Sentinel y ortofotos PNOA
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (-1968157.095, 7271532.000) ( 45d 9'51.15"W, 57d59'16.66"N)
Lower Left  (-1968157.095, 2992357.845) ( 27d 0' 0.04"W, 24d59'58.98"N)
Upper Right ( 1109656.287, 7271532.000) ( 10d 0' 2.21"E, 65d 0' 0.77"N)
Lower Right ( 1109656.287, 2992357.845) (  3d 8' 0.50"E, 26d55'11.11"N)
Center      ( -429250.404, 5131944.922) ( 14d56'30.30"W, 45d42'45.53"N)
DLL gdal204.dll (17,4 MB)
Size is 432948, 28663296
    GEOGCS["ETRS89",
    UNIT["metre",1,
Origin = (404318.828097780002281,7271532.000000000000000)
Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  404318.828, 7271532.000) (  5d 4'19.71"W, 65d33' 6.57"N)
Lower Left  (  404318.828, 2992357.845) (  3d57'53.21"W, 27d 3' 0.59"N)
Upper Right (  468954.099, 7271532.000) (  3d40'21.33"W, 65d33'52.09"N)
Lower Right (  468954.099, 2992357.845) (  3d18'47.02"W, 27d 3'11.25"N)
Center      (  436636.463, 5131944.922) (  3d49'24.02"W, 46d20'17.22"N)
As you can see, the command is exactly the same but in the first case an ERROR1 appears and also the coordinates are not the same as in the second case. What could the error be due to? Thanks and regards
[https://www.aplitop.com/descargas/firma1.jpg]
Elena Ruiz
Sofware Development & Technical Support
Tel. +34 952 43 97 71
Sumatra, 9 - 29190 Málaga (Spain)
www.aplitop.com
[cid:SocialLink_Facebook_32x32_a745adb8-c250-4372-8480-e77f503dad3d.png]<https://www.facebook.com/AplitopSL/>   [cid:SocialLink_Twitter_32x32_858247f6-9d4a-4740-a6b3-9b5ebfd98a97.png] <https://twitter.com/aplitop>    [cid:SocialLink_Linkedin_32x32_154d63de-bf68-468f-9eb0-ffed102fac77.png] <https://www.linkedin.com/company/aplitop>    [cid:SocialLink_Youtube_32x32_0dea15dd-3774-4086-be9d-f62560b70c86.png] <https://www.youtube.com/user/aplitop>
In accordance with the provisions of the European Regulation of Data Protection 2016/679 (Reglamento Europeo de Protección de Datos 2016/679), we inform you that the data and the information you provide us through this medium will be used by APLITOP, S.L., with C.I.F. B-92543396 and with address at C / Sumatra, 9, Malaga, 29190, in order to answer your questions and inform you about our products. The data provided will be kept as long as it does not request its cessation and will not be transferred to third parties except in cases where there is a legal obligation. You have the right to access your personal data, correct inaccurate data or request its deletion when the data is no longer necessary for the purposes that were collected, as well as any rights recognized in the RGPD 2016/679
<https://www.aplitop.com/Event/en/358/intergeo-2019>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/2e911906/attachment-0001.html>
Type: image/png
Desc: SocialLink_Facebook_32x32_a745adb8-c250-4372-8480-e77f503dad3d.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/2e911906/attachment-0004.png>
Type: image/png
Desc: SocialLink_Twitter_32x32_858247f6-9d4a-4740-a6b3-9b5ebfd98a97.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/2e911906/attachment-0005.png>
Type: image/png
Desc: SocialLink_Linkedin_32x32_154d63de-bf68-468f-9eb0-ffed102fac77.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/2e911906/attachment-0006.png>
Type: image/png
Desc: SocialLink_Youtube_32x32_0dea15dd-3774-4086-be9d-f62560b70c86.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/2e911906/attachment-0007.png>
