[gdal-dev] Corrupted geopackage
Isabel Kiefer
isabel at opengis.ch
Mon Feb 14 02:52:50 PST 2022
Thanks for your suggestion, Jukka! I tried all the advice from
stackoverflow. I can do ".recover", but get only the features that have
been visible all along.
In the original .gpkg, I cannot DROP the affected RTree-Index. It gives me
the same disk malformed error. But that would also have been my initial
idea...
On Mon, Feb 14, 2022 at 9:26 AM Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Without being able to see your database it is hard to give more advice
> that
> https://stackoverflow.com/questions/18259692/how-to-recover-a-corrupt-sqlite3-database/18260642
> gives. Did you try all of them? Because the problem has something to do
> with the spatial index I would have a try be dropping it and repeating the
> suggested tricks.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Isabel
> Kiefer
> *Lähetetty:* maanantai 14. helmikuuta 2022 10.17
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] Corrupted geopackage
> Hi everyone,
> I've a problem with a corrupted geopackage.
> It should contain a table with 694 entries, but only 78 are visible when
> opening the file with DB Browser for SQLite or QGIS. The table
> gpkg_ogr_contents says 694 though. When opening the .gpkg with a Notepad or
> similar, I can see that there are more than 78 entries.
> The error message in DB Browser is "database disk image is malformed in
> "PRAGMA "main".TABLE_INFO("rtree_XXX");" So it seems that there is a
> problem with the index of the concerned table.
> Does anyone know how to fix this? I tried
> https://stackoverflow.com/questions/18259692/how-to-recover-a-corrupt-sqlite3-database/18260642 but
> without success.
> Thanks in advance for your help!
> Isabel
> Isabel Kiefer
> OPENGIS.ch
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220214/857e07c3/attachment.html>
