[gdal-dev] Reading ESRI .tpkx files
Tamas Szekeres
szekerest at gmail.com
Thu Apr 27 12:51:40 PDT 2023
Is that possible to read ESRI .tpkx files in GDAL? As far as I see the
closest driver for this format is ESRIC which can read "Esri Compact Cache
V2" but it requires a conf.xml file, which is not included in the tpkx
format <https://github.com/Esri/tile-package-spec>.
Thanks,
Tamas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230427/5cbd1ab3/attachment.htm>
