[gdal-dev] JPEG2000 with COG like structure
Ujaval Gandhi
ujaval at spatialthoughts.com
Fri Apr 28 21:53:54 PDT 2023
What about using JPEG compression with GeoTIFF files instead and thus enabling
you to use COGs? In my experience, you can get pretty close to the JPEG2000 file
size with a GeoTIFF with JPEG compression.
Ujaval Gandhi
Spatial Thoughts
www.spatialthoughts.com
[https://mailtrack.io/trace/link/f9609ee3ad14467596aab38dba52bda35825bff6?url=http%3A%2F%2Fwww.spatialthoughts.com&userId=8747767&signature=0f058cfed806f1e3]
[data:image/gif;base64,R0lGODlhAQABAIAAAP///wAAACwAAAAAAQABAAACAkQBADs=3D]
On Fri, Apr 28, 2023 at 12:21 PM Tobby Moalem <mtobby59 at gmail.com> wrote:
> I am looking for a way to use my JPEG2000 over object storage (s3)
> efficiently. JPEG2000 structure is progressive by resolution, meaning that in
> order to get the maximum resolution of a tile, all previous resolutions have
> to be decoded. This leads to performing many GET request that cause slow
> performance for the user.
> I know that JPEG2000 is extremely flexible, so I wonder if there is a way to
> store each resolution level by itself (similar to COG structure), so that with
> one GET request I will receive the entire resolution level of a tile.
> Thanks in advance,
> Tobby
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org [gdal-dev at lists.osgeo.org]
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> [https://lists.osgeo.org/mailman/listinfo/gdal-dev]
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230429/7d5a91a8/attachment.htm>
