[gdal-dev] Reading s57 charts with GDAL
Aryan Landi aryan.landi at trelleborg.com
Mon Jan 30 07:00:06 PST 2023
Hi again.
Yes, ogrinfo lists the correct information. But my understanding was that GDAL works both with raster and vector, and thus exposes the org drivers.
Should I then use ogr directly instead of through GDAL?
Den 30. jan. 2023 kl. 13.42 skrev Andreas Oxenstierna <andreas.oxenstierna at t-kartor.com<mailto:andreas.oxenstierna at t-kartor.com>>:
Hi
S57 is a vector format so you need to use ogr
Check that
ogrinfo --formats
reports:
  S57 -vector- (rw+v): IHO S-57 (ENC)
Best Regards / Vänliga hälsningar
Andreas Oxenstierna
Senior Strategic Advisor
+46 733 206 831<tel:%20+46733206831>
connect on Linkedin<https://ddec1-0-en-ctp.trendmicro.com/wis/clicktime/v1/query?url=https%3a%2f%2fwww.linkedin.com%2fin%2fandreas%2doxenstierna%2d52876325%2f&umid=0df62896-8d17-451f-9cd9-35f0a552b53b&auth=b6670b9751c5c90ededae23711566d84a7ddb070-0b169618e546f2449347b11dad7b17de00f9776b>
<BBA78FFF71DD4E84AFCC262661B2FB86.png>
T-Kartor Geospatial AB
Olof Mohlins väg 12
291 62 Kristianstad
<https://ddec1-0-en-ctp.trendmicro.com/wis/clicktime/v1/query?url=www.t%2dkartor.com&umid=0df62896-8d17-451f-9cd9-35f0a552b53b&auth=b6670b9751c5c90ededae23711566d84a7ddb070-f9b1fabc496e2119c028481fdc9b5a571aaa864a>
t-kartor.com<https://ddec1-0-en-ctp.trendmicro.com/wis/clicktime/v1/query?url=www.t%2dkartor.com&umid=0df62896-8d17-451f-9cd9-35f0a552b53b&auth=b6670b9751c5c90ededae23711566d84a7ddb070-f9b1fabc496e2119c028481fdc9b5a571aaa864a>
+46 44 206 800<tel:%20+4644206800>
info at t-kartor.com<mailto:info at t-kartor.com>
This e-mail is private and confidential between the sender and the addressee. In the event of misdirection, the recipient is prohibited from using, copying or disseminating it or any information in it. Please notify the above of any such misdirection.
On 30 Jan 2023, 12:32 +0100, Aryan Landi <aryan.landi at trelleborg.com<mailto:aryan.landi at trelleborg.com>>, wrote:
You don't often get email from aryan.landi at trelleborg.com<mailto:aryan.landi at trelleborg.com>. Learn why this is important<https://ddec1-0-en-ctp.trendmicro.com/wis/clicktime/v1/query?url=https%3a%2f%2faka.ms%2fLearnAboutSenderIdentification&umid=0df62896-8d17-451f-9cd9-35f0a552b53b&auth=b6670b9751c5c90ededae23711566d84a7ddb070-afb2c5798043424a735c2d0d69a831f74877fb8a>
Hi again,
Not sure what you mean by “support files”. The command line tool returns:
ERROR 4: `US5LA26M.000' not recognized as a supported file format.
gdalinfo failed - unable to open 'US5LA26M.000
Den 30. jan. 2023 kl. 11.46 skrev bradh at frogmouth.net<mailto:bradh at frogmouth.net>:
Do you have the two support files in the same directory?
What errors do you get with the command line tool?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230130/d54de957/attachment-0001.htm>
