[gdal-dev] a_scale per band
Even Rouault even.rouault at spatialys.com
Mon Mar 23 09:58:32 PDT 2026
Le 23/03/2026 à 17:53, Javier Jimenez Shaw via gdal-dev a écrit :
> Hi
> related to https://lists.osgeo.org/pipermail/proj/2026-March/012063.html
> I was trying to change the type to int16 and scale (and offset) it to
> make it smaller, similar to the NSRS geoid model that Even suggested
> me to do in
> https://github.com/jjimenezshaw/NSRS-2022-PROJ/blob/master/make_geoid2022.sh
> But in de_lgl_bw_BWTA2017.tif there are 4 bands, and I need different
> a scale and offset for each.
> I don't see how to use a_scale and a_offset per band (documentation
> mentions "-a_scale Set band scaling value ..."). How can I do it?
Translate to VRT and edit the VRT
> Bonus track: I don't see in the new gdal CLI how to set a_scale and
> a_offset.
Can you file an enhancement ticket for gdal raster edit to add that ?
> Thanks
> Javier.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
