[geomoose-psc] support page location
Jim Klassen
klassen.js at gmail.com
Wed Mar 11 09:30:43 PDT 2015
Also, as long as we are on the topic of docs, I put these up on the
github wiki as I was running through GeoMoose installs. They should
probably be reviewed and then moved into the 2.7 docs.
https://github.com/geomoose/geomoose/wiki/Quick-and-dirty-install-of-GeoMoose-from-source-on-Debian-Wheezy,-Ubuntu-12.04-and-similar
https://github.com/geomoose/geomoose/wiki/Quick-and-dirty-install-of-GeoMoose-from-source-on-Fedora-21
On 03/11/2015 11:16 AM, Eli Adam wrote:
> Right now to get to the support pages, the path I need to take is
> geomoose.org-->Documentation-->2.7-->Getting Started-->Feature
> Overview--> then clicking on either link:
> http://www.geomoose.org/info/commercial_support.html
> http://www.geomoose.org/info/mailing_lists.html
> That seems like excessively low prominence and difficult to access.
> 1. Is there an obvious and easier route that I'm missing?
> 2. In the past, Bob (I think) has suggested putting it in the top bar.
> I generally think that is a good idea (but also generally I don't like
> a lot in navigation bars).
> 3. Hmm, our top bar is out of date (points to trac). We should remove
> "wiki" link even if it still exists with minimal use, I think that
> "Demo" and "Download" should be removed too since they are on main
> site, "Documentation" can be removed too since that is the same as
> "home".
> So my plan is to drastically reconfigure things. Does anyone have
> input or want to work together?
> Thanks, Eli
> geomoose-psc mailing list
> geomoose-psc at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geomoose-psc
More information about the geomoose-psc
