[geomoose-psc] support page location
Eli Adam
eadam at co.lincoln.or.us
Wed Mar 11 09:44:52 PDT 2015
Wow, those are great Jim! Thanks.
On Wed, Mar 11, 2015 at 9:30 AM, Jim Klassen <klassen.js at gmail.com> wrote:
> Also, as long as we are on the topic of docs, I put these up on the
> github wiki as I was running through GeoMoose installs. They should
> probably be reviewed and then moved into the 2.7 docs.
> https://github.com/geomoose/geomoose/wiki/Quick-and-dirty-install-of-GeoMoose-from-source-on-Debian-Wheezy,-Ubuntu-12.04-and-similar
> https://github.com/geomoose/geomoose/wiki/Quick-and-dirty-install-of-GeoMoose-from-source-on-Fedora-21
Our current stuff, is perhaps a little dated in that age of modern GIS
repos. http://docs.geomoose.org/2.7/docs/install_unix.html
We might want to also show use of our released tarballs.
Eli
> On 03/11/2015 11:16 AM, Eli Adam wrote:
>> Right now to get to the support pages, the path I need to take is
>> geomoose.org-->Documentation-->2.7-->Getting Started-->Feature
>> Overview--> then clicking on either link:
>> http://www.geomoose.org/info/commercial_support.html
>> http://www.geomoose.org/info/mailing_lists.html
>> That seems like excessively low prominence and difficult to access.
>> 1. Is there an obvious and easier route that I'm missing?
>> 2. In the past, Bob (I think) has suggested putting it in the top bar.
>> I generally think that is a good idea (but also generally I don't like
>> a lot in navigation bars).
>> 3. Hmm, our top bar is out of date (points to trac). We should remove
>> "wiki" link even if it still exists with minimal use, I think that
>> "Demo" and "Download" should be removed too since they are on main
>> site, "Documentation" can be removed too since that is the same as
>> "home".
>> So my plan is to drastically reconfigure things. Does anyone have
>> input or want to work together?
>> Thanks, Eli
>> geomoose-psc mailing list
>> geomoose-psc at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geomoose-psc
More information about the geomoose-psc
