[Geomoose-users] [Geomoose-developers] Search Menu / Tab
    Dan Little
    danlittle at yahoo.com
    Mon Nov 12 09:38:14 EST 2007
It should be possible, but it's going to be more of a restriction of getting mapserver to do it right, and getting the templates coordinated.  I'm going to be at a conference in Reno the rest of this week (until Friday).  But Friday I will try to get back to everyone on the list with the feature demos and enhancement requests.
-Duck
----- Original Message ----
From: "Fischer, Brian" <bfischer at houstonengineeringinc.com>
To: geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
Sent: Saturday, November 10, 2007 11:13:59 AM
Subject: Re: [Geomoose-users] [Geomoose-developers] Search Menu / Tab
<!--a:link
span.MSOHYPERLINK
a:visited
span.MSOHYPERLINKFOLLOWED
p.MSOPLAINTEXT
li.MSOPLAINTEXT
div.MSOPLAINTEXT
p.MSOACETATE
li.MSOACETATE
div.MSOACETATE
span.PLAINTEXTCHAR
span.BALLOONTEXTCHAR
 _filtered {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}
 _filtered {font-family:Consolas;panose-1:0 0 0 0 0 0 0 0 0 0;}
 _filtered {font-family:Calibri;}
/* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:Calibri;}
a:link, span.MsoHyperlink
	{color:blue;text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;text-decoration:underline;}
p.MsoPlainText, li.MsoPlainText, div.MsoPlainText
	{margin:0in;margin-bottom:.0001pt;font-size:10.5pt;font-family:Consolas;}
p.MsoAcetate, li.MsoAcetate, div.MsoAcetate
	{margin:0in;margin-bottom:.0001pt;font-size:8.0pt;font-family:Tahoma;}
span.PlainTextChar
	{font-family:Consolas;}
span.BalloonTextChar
	{font-family:Tahoma;}
span.plaintextchar0
span.balloontextchar0
span.EmailStyle23
	{font-family:Calibri;color:#1F497D;}
span.EmailStyle24
	{font-family:Arial;color:navy;}
 _filtered {margin:1.0in 1.0in 1.0in 1.0in;}
div.Section1
I don’t know whether this is
possible right now.  Dan?
geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jay Kapalczynski
Sent: Wednesday, November 07, 2007
8:56 AM
To: Dan Little; Bob Basques;
Dan
I figured something else was at work
here….that makes sense…
When I use the parks search one and have
the itemquery.map (with reference to streets and parks) and just search on the
letter "I" it brings up parks and streets…so I know that it was
drilling down in regards to the itemquery.map file….
I then made three individual
itemquery.map files for each input box….that resolved the values being
returned between both files….
But then I got stuck on why both woulnt
work….well why only the second would work….
Guess I will have to resort back to
single searches…..you have any time frame as to when this will be
resolved?
Which brings me to my second question……this
is what I am really trying to do with this application
Is it possible to create multiple
dropdownboxes on a tab and then search a dataset…..
I created a new tab with  a couple
dropdown boxes….I want to then search the Parcels Dataset fro all records
that are:
"Single Family" AND
"150000" AND "Commercial"
How do I send Map Server a multiple
search request like this?
Then have it Zoom to the extent of those
properties and have them highlighted and return specific field values to the
information Tab
THANKS FOR ALL YOUR HELP…..
Jay
[mailto:danlittle at yahoo.com]
8:44 AM
To: Jay Kapalczynski; Bob Basques;
A HA! Now I see it (do not know why
it took me so long before).
This is a general GeoMOOSE bug.  Right now only one service can be
"called" at a time.  When you put them all onto the same tab it
tries to use all of the inputs in that tab and send them all to the same
service.  Functionally it gets very confused.  Brian and I have have
been back and forth about whether to make this fix for 1.2 or 1.6
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: Bob Basques <Bob.Basques at ci.stpaul.mn.us>;
Sent: Wednesday, November 7, 2007 8:40:48 AM
This
is what I am getting when I try and search the first….It appears to be a
query error
but
when I search the second everything works fine…
NOTE:
If I move the order around it is still the first that does not work and the second
that does work.
So
it doesn’t seem to be the query or the data….they each run perfect
themselves…they don’t break down untill I place two or more on the
tab at the same time…
I
am lost here…..anyone?
-----Original
Message-----
From: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Tuesday, November 06, 2007 4:25 PM
geomoose-users at lists.sourceforge.net; Jay Kapalczynski
Subject: Re: [Geomoose-developers] Search Menu / Tab
Jay,
Not
positive about this, but I did notice the capitalization on the two different
"value" parameters are not the same, the second one is all
capitalized, there may be a need to keep them one way or the other, my gut
feeling is that they need to be capitalized, as the value is used to match
against a data column/type of some sort.
Real
quickly, you could swap their display order around and see if the same one
still works or not, then you'll know if it's the data of the query that's at
fault.
bobb
"Jay Kapalczynski" <jkapalczynski at ci.maple-grove.mn.us> wrote:
I
have been working on getting a tab running to do my searches.  I have
somewhat succeded in that I created a new tab and I can copy some of the code
that allows the user to enter a Park Name and search for it and zoom to it...
Although
I want to take this a bit further and have multiple searches on the same tab
Right
now I modified the menu to allow for searches on Park, Parcel PID, and Street
Name.
Each
one is working properly from the Menu
My
problem is when I try and bring this code to the Tab..as long as I stay with
just one of the searches I am ok.it breaks down when I try and bring more than
one..then only the last one works...
I
created a new entry in the Menue Title (statemenu.xml)
<menu title="Search">
<item title="Search for Parks" href="javascript:ServManager.startService('Search
for Parks')"/>
<item title="Search for PID"
href="javascript:ServManager.startService('Search for PID')"/>
                            <item
title="Search for Street" href="javascript:ServManager.startService('Search
for Street')"/>
<item title="Search for Stuff"
href="javascript:ServManager.startService('Search for Stuff')"/>
              </menu>
I
created a new entry in the service title (statedemo.xml)
<service title="Search for Stuff" selectable="false"
default="false" locked="true"
div="StuffSearch">
               <url>/cgi-bin/mapserv.exe</url>
<input type="hidden" name="map"
value="/ms4w/apps/GeoMOOSE/maps_statedemo/itemquery_Stuff.map"/>
<input type="hidden" name="mode"
value="nquery"/>
<input type="user" name="id" title="Zoom to
Stuff:"/>
</service>
I
create a new entry for the search (statedemo.html)
<div id="StuffSearch">
<font color="black"><b>Search for Park:</b></font><br/>
<input name="id"/><input type="submit"
value="Search_Park"/>
value="/ms4w/apps/GeoMOOSE/maps_statedemo/itemquery.map"/>
<input type="hidden" name="mode" value="nquery"/>
<br><i>Enter Park Name.<i/>
PID:</b></font><br/>
value="SEARCH_PID"/>
              <input
<br><i>Enter PID number.<i/> </div>
When
written like above you can see both of them but only the second one works..the
first errors out.
ANY
THOUGHTS WH Y BOTH WILL NOT WORK?
OR
ANY THOUGHTS HOW I CAN GET THIS TO WORK?
THanks
Jay
-----Inline Attachment Follows-----
This SF.net email is sponsored by:
Splunk Inc.
Still grepping through log files to find problems?  Stop.
Now Search log events and configuration files using AJAX and a browser.
Download your FREE copy of Splunk now >> http://get.splunk.com/
This SF.net email is sponsored by: Splunk Inc.
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Skipped content of type multipart/related
More information about the Geomoose-users
