[Geomoose-users] MAXSCALE / MINSCALE in mapbook not applicable
mapfile layers?
FRANZ OKYERE
franzzoa at hotmail.com
Tue Aug 4 07:34:41 EDT 2009
> Date: Tue, 4 Aug 2009 13:18:38 +0200
> From: coffee at uni-bonn.de
> To: franzzoa at hotmail.com
> Subject: Re: [Geomoose-users] MAXSCALE / MINSCALE in mapbook not applicable mapfile layers?
> > Dear all,
> > I am having a similar issue but I am happy that I am not the only one
> > having the problem. The changes I make in my mapfile and even mapbook
> > does not seem to have any effect in the interface. I suspect a script or
> > two needs modification. I am using a mapfile- I want to
> > show geographical coordinates, as in longlat. Thanks Coffy
> > Franz.
> > AM- Surveys Ltd
> > GHana
> > > Date: Tue, 4 Aug 2009 11:58:31 +0200
> > > To: geomoose-users at lists.sourceforge.net
> > > Subject: [Geomoose-users] MAXSCALE / MINSCALE in mapbook not
> > > Dear all,
> > > in GM2 I set maxscale / minscale at layer level in my mapbook.
> > > I works perfectly well when using the feature with WMS layers that I
> > > include directly into GM without using a mapfile and turns these layers
> > > on/off at the specified scale.
> > > However, when using "maxscale" on layer from a mapfile these settings
> > > seem to have no effect other than controlling the use of CSS for
> > > inscale/outscale in the catalogue. True or false?
> > > The reason I am asking is that if I set
> > > #mapfile
> > > MAXSCALEDENOM = 5000000
> > > and
> > > #mapbook catalogue
> > > <layer ... maxscale="5000000"/>
> > > the two settings seem not to correspond thoroughly. The layer will still
> > > be shown on the map but marked as "outscale" in the catalogue when
> > > zooming for instance to 1:5000500 (as shown in the GM scale box).
> > > In order to make both setting correspond roughly I have to change my
> > > mapfile to
> > > MAXSCALEDENOM = 5006600
> > > which is kinda weird and makes administration a bit more painful.
> > > I got "meters" set as units in both my mapbook & mapfiles? Do I need
> > > something else?
> > > Thanks,
> > > Nils
> > > Center for Development Research
> > > Department of Ecology and Resource Management
> > > Walter-Flex-Strasse 3
> > > 53113 Bonn (Germany)
> > > Tel.: +49 (0) 228 - 73-1793
> > > FAX: +49 (0) 228 - 73-1889
> > > E-Mail: coffee at uni-bonn.de
> > > Web: http://www.cofis.info/atlas
> > > http://www.coffee.uni-bonn.de
> > > Let Crystal Reports handle the reporting - Free Crystal Reports 2008
> > 30-Day
> > > trial. Simplify your report design, integration and deployment - and
> > focus on
> > > what you do best, core application coding. Discover what's new with
> > > Crystal Reports now. http://p.sf.net/sfu/bobj-july
> > > _______________________________________________
> > > Geomoose-users mailing list
> > > Geomoose-users at lists.sourceforge.net
> > > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> > Celebrate a decade of Messenger with free winks, emoticons, display
> > pics, and more. Get Them Now
> > <http://clk.atdmt.com/UKM/go/157562755/direct/01/>
_________________________________________________________________
Windows Live Messenger: Thanks for 10 great years—enjoy free winks and emoticons.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090804/c427ca50/attachment.html
More information about the Geomoose-users
