[Geomoose-users] GeoMOOSE 2.0 demo problems
Brian Fischer
bfischer at houstoneng.com
Tue Aug 18 19:07:57 EDT 2009
Devon,
This is a known issue and will be fixed in version 2.0.1. To fix this you need to either add the "MAXSIZE" parameter to the globals.map or to each individual map file.
I use MAXSIZE 10000 that means mapserver will generate a image up to 10000 pixels. The default is 2048.
-Brian
-----Original Message-----
From: Devon Piernot [mailto:piernotd at uwplatt.edu]
Sent: Tuesday, August 18, 2009 3:52 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] GeoMOOSE 2.0 demo problems
Hey all,
I was previously using geomoose 1.6.1 with ms4w 2.3.1 and I am trying to upgrade to geomoose 2.0 but I have encountered some problems. In the demo application, all imagery works great, but none of the mapfiles display properly. I can see that they display fine in the inset, but on the main map it is just a blank pink over the entire map. Has anyone else encountered this problem?
thanks
Devon Piernot
GIS / Web Developer
Southwestern Wisconsin Regional Planning Commission
(608) 342-6065
www.swwrpc.org
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
