[Geomoose-users] Legend issue
Dan Little
danlittle at yahoo.com
Wed Aug 19 00:45:27 EDT 2009
Nils,
I was trying to recreate this as a bug tonight... but the legends and layers appear to be toggling properly. The legends do not force themselves off, you do need to hit the "minus" button for them to disappear.
----- Original Message ----
> From: Dan Little <danlittle at yahoo.com>
> To: coffee at uni-bonn.de; GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Wednesday, July 29, 2009 1:38:06 PM
> Subject: Re: [Geomoose-users] Legend issue
> I marked this in trac as ticket #4.
> > From: CoFIS Web
> > To: GeoMoose Mailing list
> > Sent: Wednesday, July 29, 2009 7:09:22 AM
> > Dear all,
> > thanks to suggestion on the mapserver list, I replaced the dashes in my layer
> > names (in the mapfile & mapbook) with underscores and now the problem is gone
> > almost:
> > I can switch on and off the individual layers and they only appear at their
> > respective positions in the legend. However, if I switch one of the layers of
> > may mapfile on (from the legend) I can show the signature of the other layer
> in
> > the legend by using the drop-down button without this particular layer being
> > switched on (screenshot).
> > Can this be changed somehow? If you need to see my mapfile, I'd be happy to
> send
> > it.
> > Thanks,
> > Nils
> > CoFIS Web schrieb:
> > > Dear Len,
> > > yes, the layers are in the same mapfile. I tried setting the STATUS to ON
> and
> > OFF at layer level. But still it results in the same issue - signatures of
> both
> > layers appear in the legend.
> > > Any hints? I'll search the Mapserver mailing list as well.
> > > Thanks,
> > > Nils
> > > Len Kne schrieb:
> > >> Are both layers in the same mapfile? If yes, check the layer STATUS in
> your
> > mapfile. If STATUS is set to DEFAULT, that layer is included whenever a
> request
> > for a legend is made. Try setting STATUS to ON.
> > >> Len
> > >> ______________________________
> > >> Len Kne
> > >> lenkne at yahoo.com
> > >> *From:* CoFIS Web
> > >> *To:* GeoMoose Mailing list
> > >> *Sent:* Thursday, June 25, 2009 2:48:55 AM
> > >> *Subject:* [Geomoose-users] Legend issue
> > >> Dear all,
> > >> in GM2 I have a mapfile with two layers.
> > >> When turning the first of these layers on from the legend, the respective
> > signature will appear in the legend at its respective location (as expected)
> AND
> > the location of the second layer. When turning the second layer on, its
> > signature will appear on its respective location in the legend (as expected)
> AND
> > be added to the legend signature of the first layer (not wanted).
> > >> How can I change this? I added two screenshots for clarification. Mapbook
> > snippets are below.
> > >> Thanks,
> > >> Nils
> > >> ./conservation.map
> > legend="true" status="off"/>
> > src="conservation/biores_ecff-yayu01" legend="true" status="on"/>
> > >> -- Center for Development Research
> > >> Department of Ecology and Resource Management
> > >> Walter-Flex-Strasse 3
> > >> 53113 Bonn (Germany)
> > >> Tel.: +49 (0) 228 - 73-1793
> > >> FAX: +49 (0) 228 - 73-1889
> > >> E-Mail: coffee at uni-bonn.de
> > >> Web: http://www.cofis.info/atlas
> > >> http://www.coffee.uni-bonn.de
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
