Nevermind, I found a few issues... working on it.
----- Original Message ----
> From: Dan Little <danlittle at yahoo.com>
> To: Dan Little <danlittle at yahoo.com>; coffee at uni-bonn.de; GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Tuesday, August 18, 2009 11:45:27 PM
> Subject: Re: [Geomoose-users] Legend issue
> Nils,
> I was trying to recreate this as a bug tonight... but the legends and layers
> appear to be toggling properly. The legends do not force themselves off, you do
> need to hit the "minus" button for them to disappear.
> > From: Dan Little
> > To: coffee at uni-bonn.de; GeoMoose Mailing list
> > Sent: Wednesday, July 29, 2009 1:38:06 PM
> > I marked this in trac as ticket #4.
> > > From: CoFIS Web
> > > To: GeoMoose Mailing list
> > > Sent: Wednesday, July 29, 2009 7:09:22 AM
> > > Dear all,
> > > thanks to suggestion on the mapserver list, I replaced the dashes in my
> layer
> > > names (in the mapfile & mapbook) with underscores and now the problem is
> gone
> > > almost:
> > > I can switch on and off the individual layers and they only appear at their
> > > respective positions in the legend. However, if I switch one of the layers
> of
> > > may mapfile on (from the legend) I can show the signature of the other layer
> > in
> > > the legend by using the drop-down button without this particular layer being
> > > switched on (screenshot).
> > > Can this be changed somehow? If you need to see my mapfile, I'd be happy to
> > send
> > > it.
> > > Thanks,
> > > Nils
> > > CoFIS Web schrieb:
> > > > Dear Len,
> > > > yes, the layers are in the same mapfile. I tried setting the STATUS to ON
> > and
> > > OFF at layer level. But still it results in the same issue - signatures of
> > both
> > > layers appear in the legend.
> > > > Any hints? I'll search the Mapserver mailing list as well.
> > > > Thanks,
> > > > Nils
> > > > Len Kne schrieb:
> > > >> Are both layers in the same mapfile? If yes, check the layer STATUS in
> > your
> > > mapfile. If STATUS is set to DEFAULT, that layer is included whenever a
> > request
> > > for a legend is made. Try setting STATUS to ON.
> > > >> Len
> > > >> ______________________________
> > > >> Len Kne
> > > >> lenkne at yahoo.com
> > > >> *From:* CoFIS Web
> > > >> *To:* GeoMoose Mailing list
> > > >> *Sent:* Thursday, June 25, 2009 2:48:55 AM
> > > >> *Subject:* [Geomoose-users] Legend issue
> > > >> Dear all,
> > > >> in GM2 I have a mapfile with two layers.
> > > >> When turning the first of these layers on from the legend, the respective
> > > signature will appear in the legend at its respective location (as expected)
> > AND
> > > the location of the second layer. When turning the second layer on, its
> > > signature will appear on its respective location in the legend (as expected)
> > AND
> > > be added to the legend signature of the first layer (not wanted).
> > > >> How can I change this? I added two screenshots for clarification. Mapbook
> > > snippets are below.
> > > >> Thanks,
> > > >> Nils
> > > >> ./conservation.map
> > > legend="true" status="off"/>
> > > src="conservation/biores_ecff-yayu01" legend="true" status="on"/>
> > > >> -- Center for Development Research
> > > >> Department of Ecology and Resource Management
> > > >> Walter-Flex-Strasse 3
> > > >> 53113 Bonn (Germany)
> > > >> Tel.: +49 (0) 228 - 73-1793
> > > >> FAX: +49 (0) 228 - 73-1889
> > > >> E-Mail: coffee at uni-bonn.de
> > > >> Web: http://www.cofis.info/atlas
> > > >> http://www.coffee.uni-bonn.de
> > Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> > trial. Simplify your report design, integration and deployment - and focus on
> > what you do best, core application coding. Discover what's new with
> > Crystal Reports now. http://p.sf.net/sfu/bobj-july
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
