[Geomoose-users] Legend issue
Dan Little
danlittle at yahoo.com
Wed Aug 19 01:47:51 EDT 2009
Hey Duck!
Yes?
I think I've fixed the legend problem.
Cool, where is it?
Oh, it's in svn trunk.
R-E-A-L-Y-?
Yep.
But I hate SVN.
Don't worry, I'm going to try to have an update package ready by the end of the week.
Cool.
----- Original Message ----
> From: Dan Little <danlittle at yahoo.com>
> To: Dan Little <danlittle at yahoo.com>; coffee at uni-bonn.de; GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Wednesday, August 19, 2009 12:26:55 AM
> Subject: Re: [Geomoose-users] Legend issue
> Nevermind, I found a few issues... working on it.
> > From: Dan Little
> > To: Dan Little ; coffee at uni-bonn.de; GeoMoose Mailing
> list
> > Sent: Tuesday, August 18, 2009 11:45:27 PM
> > Nils,
> > I was trying to recreate this as a bug tonight... but the legends and layers
> > appear to be toggling properly. The legends do not force themselves off, you
> do
> > need to hit the "minus" button for them to disappear.
> > > From: Dan Little
> > > To: coffee at uni-bonn.de; GeoMoose Mailing list
> > > Sent: Wednesday, July 29, 2009 1:38:06 PM
> > > I marked this in trac as ticket #4.
> > > > From: CoFIS Web
> > > > To: GeoMoose Mailing list
> > > > Sent: Wednesday, July 29, 2009 7:09:22 AM
> > > > Dear all,
> > > > thanks to suggestion on the mapserver list, I replaced the dashes in my
> > layer
> > > > names (in the mapfile & mapbook) with underscores and now the problem is
> > gone
> > > > almost:
> > > > I can switch on and off the individual layers and they only appear at
> their
> > > > respective positions in the legend. However, if I switch one of the layers
> > of
> > > > may mapfile on (from the legend) I can show the signature of the other
> layer
> > > in
> > > > the legend by using the drop-down button without this particular layer
> being
> > > > switched on (screenshot).
> > > > Can this be changed somehow? If you need to see my mapfile, I'd be happy
> to
> > > send
> > > > it.
> > > > Thanks,
> > > > Nils
> > > > CoFIS Web schrieb:
> > > > > Dear Len,
> > > > > yes, the layers are in the same mapfile. I tried setting the STATUS to
> ON
> > > and
> > > > OFF at layer level. But still it results in the same issue - signatures of
> > > both
> > > > layers appear in the legend.
> > > > > Any hints? I'll search the Mapserver mailing list as well.
> > > > > Thanks,
> > > > > Nils
> > > > > Len Kne schrieb:
> > > > >> Are both layers in the same mapfile? If yes, check the layer STATUS in
> > > your
> > > > mapfile. If STATUS is set to DEFAULT, that layer is included whenever a
> > > request
> > > > for a legend is made. Try setting STATUS to ON.
> > > > >> Len
> > > > >> ______________________________
> > > > >> Len Kne
> > > > >> lenkne at yahoo.com
> > > > >> *From:* CoFIS Web
> > > > >> *To:* GeoMoose Mailing list
> > > > >> *Sent:* Thursday, June 25, 2009 2:48:55 AM
> > > > >> *Subject:* [Geomoose-users] Legend issue
> > > > >> Dear all,
> > > > >> in GM2 I have a mapfile with two layers.
> > > > >> When turning the first of these layers on from the legend, the
> respective
> > > > signature will appear in the legend at its respective location (as
> expected)
> > > AND
> > > > the location of the second layer. When turning the second layer on, its
> > > > signature will appear on its respective location in the legend (as
> expected)
> > > AND
> > > > be added to the legend signature of the first layer (not wanted).
> > > > >> How can I change this? I added two screenshots for clarification.
> Mapbook
> > > > snippets are below.
> > > > >> Thanks,
> > > > >> Nils
> > > > >> ./conservation.map
> > > > legend="true" status="off"/>
> > > > src="conservation/biores_ecff-yayu01" legend="true" status="on"/>
> > > > >> -- Center for Development Research
> > > > >> Department of Ecology and Resource Management
> > > > >> Walter-Flex-Strasse 3
> > > > >> 53113 Bonn (Germany)
> > > > >> Tel.: +49 (0) 228 - 73-1793
> > > > >> FAX: +49 (0) 228 - 73-1889
> > > > >> E-Mail: coffee at uni-bonn.de
> > > > >> Web: http://www.cofis.info/atlas
> > > > >> http://www.coffee.uni-bonn.de
> > > Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> > > trial. Simplify your report design, integration and deployment - and focus
> on
> > > what you do best, core application coding. Discover what's new with
> > > Crystal Reports now. http://p.sf.net/sfu/bobj-july
> > > _______________________________________________
> > > Geomoose-users mailing list
> > > Geomoose-users at lists.sourceforge.net
> > > https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
