[Geomoose-users] Multiple Geomoose sites
CoFIS Web coffee at uni-bonn.de
Wed Aug 19 09:35:05 EDT 2009
Richard,
Copying the entire directory of GM2, as Mark suggested, works fine for
me (and has been working fine in GM 1.6.x).
Nils
Mark Volz schrieb:
> Rick,
> I think the call up order is:
> Htdocs\geomoose.html
> Htdocs\compiled.js
> Htdocs\php\getmapbook.php
> Htdocs\php\config.php
> Conf\settings.ini
> Conf\mapbook_demo.html
> You have two choices:
> 1)  You could modify those files to create a second gm2 site however, most of
> the functions in the php directory link to index.php.  You would end up
> having to modify all of those functions if your site uses different data.
> 2)  It might be easier to copy the entire geomoose2 directory to a new
> directory.  You will need to set up a virtual directory by making a copy of
> \ms4w\httpd.d\httpd_geomoose2_ms4w.conf.
> * I think all of the directories are relative in GM2 so you won't have to
> search for ms4w\apps\geomoose2 in every file then change it to
> ms4w\apps\mysecondgeomoose
> * You would have to repeat your work for any updates to geomoose
> Mark Volz
> GIS Specialist
> Lyon County, MN
> (507) 532-8218
> Message: 2
> Date: Thu, 13 Aug 2009 11:54:13 -0500
> From: "Moore, Richard J" <richard.moore at mnsu.edu>
> Subject: [Geomoose-users] Multiple Sites in GM 2.0
> To: "'geomoose-users at lists.sourceforge.net'"
> 	<geomoose-users at lists.sourceforge.net>
> Message-ID:
> 	<0821406D702C1442A50855B521808F380126BB889F1F at EX2.Campus.mnsu.edu>
> Content-Type: text/plain; charset="us-ascii"
> In GM 2.0, which files need to be copied to make multiple sites within
> GeoMoose?  I've noticed a few but want to double check with the experts.
> It seems like it should be:
> Mapbook.xml in the CONF folder
> Possible Settings.ini in CONF folder
> Possibly compiled.js in htdocs folder
> GeoMoose.html in htdocs folder
> A lot of those seem similar to the GM 1.6.1, but was unsure of the path that
> GeoMoose takes when it is launched.
> I assume it is Geomoose.html then compiled.js and then references to the
> other two along the way
> If you could shed some light on exactly which files we need to change if we
> are making a simple application, as well as which files need to be
> duplicated/copied for multiple applications.
> Thanks,
> Rick Moore
> GIS Research Analyst
> Water Resources Center
> 184 Trafton Science Center South
> Minnesota State University, Mankato
> Mankato, MN   56001
> (507) 389-3267
> http://mavdisk.mnsu.edu/moorer2/
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now.  http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
Center for Development Research
Department of Ecology and Resource Management
Walter-Flex-Strasse 3
53113 Bonn (Germany)
Tel.:   +49 (0) 228 - 73-1793
FAX:    +49 (0) 228 - 73-1889
E-Mail: coffee at uni-bonn.de
Web:    http://www.cofis.info/atlas
         http://www.coffee.uni-bonn.de
More information about the Geomoose-users mailing list
