[Geomoose-users] Feature requests and a Tip
    Bob Basques
    Bob.Basques at ci.stpaul.mn.us
    Tue May  5 16:49:07 EDT 2009
A couple of additions . . .
* Make the side panel collapsible, and resizeable (horizontally)
* Wide-screen mode, some thoughts about setting up tiled requests (from GeoMoose upon hitting the image limits, might be in order.  Something like GeoMoose automatically requesting tiles if the screen size get to big.  Hmm, this is an interesting idea, does MapServer have a way to query the MAXSIZE value of a Mapfile (Other than via a template?)
bobb
>>> Brent Fraser <bfraser at geoanalytic.com> 05/05/09 2:36 PM >>>
A few feature requests for Geomoose 2:
1. Make the side panel collapsible like v1.6.1
2. On clicking the Search button, set the keyboard focus to the text box.
3. Have check box at the Group level to turn off/on entire sets of layers.
4. Have dependent layers (like Mapserver's LAYER -> REQUIRES) so if I turn a layer off, it's labels (rendered in a separate map file so they are always on top of everything else) will turn off too.
5. Have check boxes for the Mapserver LAYER level too.
And here's a tip for those who like to maximize their mapping:
	When using the browser (Firefox, IE, etc) on a GeoMoose site, press F11 to switch to Full-screen mode while in the browser.  This will get rid of all those pesky browser title, status, tool, and menu bars.  Press F11 again to return to standard windowed browsing.  But don't try this with dual (or more!) display setups; Mapserver is set by default to render a maximum of 2048 and the layers will fail to render (for those building GeoMoose sites, set the MAP's MAXSIZE to 4096 or larger to handle dual displays).
Best Regards,
Brent Fraser
GeoAnalytic Inc.
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
