[Geomoose-users] Feature requests and a Tip
Dan Little
danlittle at yahoo.com
Thu May 14 14:41:58 EDT 2009
Hiliting the Identify is problematic as it spans multiple layers (it is a "drill down" identify).
Also, isn't there some saying about squeaky wheels? LOL!
As of now I'm putting a feature freeze on 2.0, I want to test the latest batch of features and then wrap up a 2.0 release package. Brian and I also need to throw the demo back together with the new features.
So, TEST PEOPLE TEST!!!
----- Original Message ----
> From: Brent Fraser <bfraser at geoanalytic.com>
> To: Dan Little <danlittle at yahoo.com>
> Cc: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
> Sent: Thursday, May 14, 2009 1:02:58 PM
> Subject: Re: [Geomoose-users] Feature requests and a Tip
> Dan,
> Excellent!
> And of course the reward for doing good work is YAFR
> (Yet-Another-Feature-Request):
> 6. Enable hi-light for the Identify operation (Select and Search already have
> it)
> A work-around would be to not use the Identify at all; just use the Select.
> But GeoMoose 2 doesn't like a single point for a search polygon. Using the demo
> on Houston Eng., when I do a single double click for a polygon, I get:
> Fatal error: [MapServer Error]: msGEOSShapeFromWKT(): Error reading WKT
> geometry "POLYGON((486301.3095538394 4939162.684125084,486301.3095538394
> 4939162.684125084))". in E:\ms4w\apps\GeoMOOSE\gm2_demo\htdocs\php\select.php on
> line 42
> And using only a line gives:
> Fatal error: Call to a member function buffer() on a non-object in
> E:\ms4w\apps\GeoMOOSE\gm2_demo\htdocs\php\select.php on line 109
> Thanks!
> Brent Fraser
> Dan Little wrote:
> > I've implemented suggestions 2/3 ... I probably won't do #1 without
> sponsorship as leaving that feature off has really really sped up and cleaned up
> the UI rendering code.
> >> From: Brent Fraser
> >> To: Dan Little
> >> Sent: Tuesday, May 5, 2009 3:23:38 PM
> >> Darn! Now I've HAVE to download the Beta and give it a go...
> >> Many Thanks,
> >> Brent
> >> Dan Little wrote:
> >>> Hey Brent thank you for the feature requests and the tip...
> >>> Here's something you might want to look into for 4/5...
> >>> You can actually do "dependent" layers in side of GM2 right now AND use
> >> mapserver "layer" levels ... for example...
> >>> all/labels.map
> >>> all/shapes.map
> >>> Then in the , to implement "requires..."
> >>> Or to implement mapfile level layering...
> >>>> From: Brent Fraser
> >>>> To: GeoMOOSE Users List
> >>>> Sent: Tuesday, May 5, 2009 2:35:07 PM
> >>>> Subject: [Geomoose-users] Feature requests and a Tip
> >>>> A few feature requests for Geomoose 2:
> >>>> 1. Make the side panel collapsible like v1.6.1
> >>>> 2. On clicking the Search button, set the keyboard focus to the text box.
> >>>> 3. Have check box at the Group level to turn off/on entire sets of layers.
> >>>> 4. Have dependent layers (like Mapserver's LAYER -> REQUIRES) so if I turn
> a
> >> layer off, it's labels (rendered in a separate map file so they are always on
> >> top of everything else) will turn off too.
> >>>> 5. Have check boxes for the Mapserver LAYER level too.
> >>>> And here's a tip for those who like to maximize their mapping:
> >>>> When using the browser (Firefox, IE, etc) on a GeoMoose site, press F11
> >> to switch to Full-screen mode while in the browser. This will get rid of all
> >> those pesky browser title, status, tool, and menu bars. Press F11 again to
> >> return to standard windowed browsing. But don't try this with dual (or
> more!)
> >> display setups; Mapserver is set by default to render a maximum of 2048 and
> the
> >> layers will fail to render (for those building GeoMoose sites, set the MAP's
> >> MAXSIZE to 4096 or larger to handle dual displays).
> >>>> Best Regards,
> >>>> Brent Fraser
> >>>> GeoAnalytic Inc.
> >>>> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
> >>>> production scanning environment may not be a perfect world - but thanks to
> >>>> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK
> i700
> >>>> Series Scanner you'll get full speed at 300 dpi even with all image
> >> processing features enabled. http://p.sf.net/sfu/kodak-com
> >>>> _______________________________________________
> >>>> Geomoose-users mailing list
> >>>> Geomoose-users at lists.sourceforge.net
> >>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
