[Geomoose-users] Feature requests and a Tip
Brent Fraser
bfraser at geoanalytic.com
Thu May 14 14:02:58 EDT 2009
Dan,
Excellent!
And of course the reward for doing good work is YAFR (Yet-Another-Feature-Request):
6. Enable hi-light for the Identify operation (Select and Search already have it)
A work-around would be to not use the Identify at all; just use the Select.
But GeoMoose 2 doesn't like a single point for a search polygon. Using the demo on Houston Eng., when I do a single double click for a polygon, I get:
Fatal error: [MapServer Error]: msGEOSShapeFromWKT(): Error reading WKT geometry "POLYGON((486301.3095538394 4939162.684125084,486301.3095538394 4939162.684125084))". in E:\ms4w\apps\GeoMOOSE\gm2_demo\htdocs\php\select.php on line 42
And using only a line gives:
Fatal error: Call to a member function buffer() on a non-object in E:\ms4w\apps\GeoMOOSE\gm2_demo\htdocs\php\select.php on line 109
Thanks!
Brent Fraser
Dan Little wrote:
> I've implemented suggestions 2/3 ... I probably won't do #1 without sponsorship as leaving that feature off has really really sped up and cleaned up the UI rendering code.
> ----- Original Message ----
>> From: Brent Fraser <bfraser at geoanalytic.com>
>> To: Dan Little <danlittle at yahoo.com>
>> Cc: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
>> Sent: Tuesday, May 5, 2009 3:23:38 PM
>> Subject: Re: [Geomoose-users] Feature requests and a Tip
>> Darn! Now I've HAVE to download the Beta and give it a go...
>> Many Thanks,
>> Brent
>> Dan Little wrote:
>>> Hey Brent thank you for the feature requests and the tip...
>>> Here's something you might want to look into for 4/5...
>>> You can actually do "dependent" layers in side of GM2 right now AND use
>> mapserver "layer" levels ... for example...
>>> all/labels.map
>>> all/shapes.map
>>> Then in the , to implement "requires..."
>>> Or to implement mapfile level layering...
>>>> From: Brent Fraser
>>>> To: GeoMOOSE Users List
>>>> Sent: Tuesday, May 5, 2009 2:35:07 PM
>>>> Subject: [Geomoose-users] Feature requests and a Tip
>>>> A few feature requests for Geomoose 2:
>>>> 1. Make the side panel collapsible like v1.6.1
>>>> 2. On clicking the Search button, set the keyboard focus to the text box.
>>>> 3. Have check box at the Group level to turn off/on entire sets of layers.
>>>> 4. Have dependent layers (like Mapserver's LAYER -> REQUIRES) so if I turn a
>> layer off, it's labels (rendered in a separate map file so they are always on
>> top of everything else) will turn off too.
>>>> 5. Have check boxes for the Mapserver LAYER level too.
>>>> And here's a tip for those who like to maximize their mapping:
>>>> When using the browser (Firefox, IE, etc) on a GeoMoose site, press F11
>> to switch to Full-screen mode while in the browser. This will get rid of all
>> those pesky browser title, status, tool, and menu bars. Press F11 again to
>> return to standard windowed browsing. But don't try this with dual (or more!)
>> display setups; Mapserver is set by default to render a maximum of 2048 and the
>> layers will fail to render (for those building GeoMoose sites, set the MAP's
>> MAXSIZE to 4096 or larger to handle dual displays).
>>>> Best Regards,
>>>> Brent Fraser
>>>> GeoAnalytic Inc.
>>>> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
>>>> production scanning environment may not be a perfect world - but thanks to
>>>> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
>>>> Series Scanner you'll get full speed at 300 dpi even with all image
>> processing features enabled. http://p.sf.net/sfu/kodak-com
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.sourceforge.net
>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
