[Geomoose-users] Feature requests and a Tip
Dan Little
danlittle at yahoo.com
Thu May 14 11:56:50 EDT 2009
I've implemented suggestions 2/3 ... I probably won't do #1 without sponsorship as leaving that feature off has really really sped up and cleaned up the UI rendering code.
----- Original Message ----
> From: Brent Fraser <bfraser at geoanalytic.com>
> To: Dan Little <danlittle at yahoo.com>
> Cc: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
> Sent: Tuesday, May 5, 2009 3:23:38 PM
> Subject: Re: [Geomoose-users] Feature requests and a Tip
> Darn! Now I've HAVE to download the Beta and give it a go...
> Many Thanks,
> Brent
> Dan Little wrote:
> > Hey Brent thank you for the feature requests and the tip...
> > Here's something you might want to look into for 4/5...
> > You can actually do "dependent" layers in side of GM2 right now AND use
> mapserver "layer" levels ... for example...
> > all/labels.map
> > all/shapes.map
> > Then in the , to implement "requires..."
> > Or to implement mapfile level layering...
> >> From: Brent Fraser
> >> To: GeoMOOSE Users List
> >> Sent: Tuesday, May 5, 2009 2:35:07 PM
> >> Subject: [Geomoose-users] Feature requests and a Tip
> >> A few feature requests for Geomoose 2:
> >> 1. Make the side panel collapsible like v1.6.1
> >> 2. On clicking the Search button, set the keyboard focus to the text box.
> >> 3. Have check box at the Group level to turn off/on entire sets of layers.
> >> 4. Have dependent layers (like Mapserver's LAYER -> REQUIRES) so if I turn a
> layer off, it's labels (rendered in a separate map file so they are always on
> top of everything else) will turn off too.
> >> 5. Have check boxes for the Mapserver LAYER level too.
> >> And here's a tip for those who like to maximize their mapping:
> >> When using the browser (Firefox, IE, etc) on a GeoMoose site, press F11
> to switch to Full-screen mode while in the browser. This will get rid of all
> those pesky browser title, status, tool, and menu bars. Press F11 again to
> return to standard windowed browsing. But don't try this with dual (or more!)
> display setups; Mapserver is set by default to render a maximum of 2048 and the
> layers will fail to render (for those building GeoMoose sites, set the MAP's
> MAXSIZE to 4096 or larger to handle dual displays).
> >> Best Regards,
> >> Brent Fraser
> >> GeoAnalytic Inc.
> >> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
> >> production scanning environment may not be a perfect world - but thanks to
> >> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
> >> Series Scanner you'll get full speed at 300 dpi even with all image
> processing features enabled. http://p.sf.net/sfu/kodak-com
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.sourceforge.net
> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
