[Geomoose-users] [Fwd: Re: Installation documentation for Ubuntu/error logs?]
Brent Fraser bfraser at geoanalytic.com
Fri Nov 6 13:09:58 EST 2009
I meant to send this to the list too...
---------------------------- Original Message ----------------------------
Subject: Re: [Geomoose-users] Installation documentation for Ubuntu/error
    logs? From:    "Brent Fraser" <bfraser at geoanalytic.com>
Date:    Fri, November 6, 2009 11:08 am
To:      "Matthew Burton-Kelly" <matthew.burtonkelly at gmail.com>
Matt,
  Based on what's delivered to my browser (and what isn't) when accessing
your site, it looks like the mapbook.xml is not being read (or parsed
successfully) by the GeoMoose JavaScript.   Is PHP working on your server?
 If not you can still have the mapbook.xml file loaded (see
http://www.geomoose.org/moose/howto/getmapbook.html)
Brent Fraser
> Hello all,
> I saw that there was a recent comment about installing GeoMOOSE on Linux
and that there seems not to be any documentation about this. I'm
currently trying to make things work in Ubuntu, but I've hit a dead end.
> This is what I've done so far:
> http://protichnoctem.blogspot.com/2009/11/my-ongoing-battle-with-geomoose-201-un.html
Any help would be appreciated.  My install is located at
> http://134.129.143.110/geomoose2/geomoose.html
> Two other questions
> Is there an error log somewhere?  No errors show up for my install, but
no maps do either.
> In what directory should mapfiles be placed?
> I'm more than willing to add to the documentation for this application
as I learn, but first I need to be able to install it!
> Thanks,
> Matt BK
> Matthew Burton-Kelly, M.S.
> Graduate Student
> Department of Geology and Geological Engineering
> University of North Dakota
> (802) 922-3696
> matthew.burton.kelly at und.nodak.edu
> http://uweb.und.nodak.edu/~matthew.burton.kelly/
> "About thirty years ago there was much talk that geologists ought only
to observe and not theorize; and I well remember someone saying that at
this rate a man might as well go into a gravelpit and count the pebbles
and describe the colors.  How odd it is that anyone should not see that
all observation must be for or against some view if it is to be of any
service!"
> -Charles Darwin, in an 1861 letter to Henry Fawcett.
Let Crystal Reports handle the reporting - Free Crystal Reports 2008
30-Day
> trial. Simplify your report design, integration and deployment - and
focus on
> what you do best, core application coding. Discover what's new with
Crystal Reports now.  http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
