[Geomoose-users] itemquery.php timeout
Dan Little
danlittle at yahoo.com
Thu Nov 19 20:48:23 EST 2009
There are two things to do:
1) Increase the maximum allowed run time in php.ini.
2) Make your dataset faster. 180,000 records, I hate to say, is not that big. I'd suggest throwing them in PostgreSQL and index both the WKB_GEOMETRY column and the columns used to store the owner name. That way searches will be notably faster.
----- Original Message ----
> From: Johan Forsman <Johan.Forsman at LA.GOV>
> To: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
> Sent: Thu, November 19, 2009 3:17:17 PM
> Subject: [Geomoose-users] itemquery.php timeout
> Hello All:
> This is another followup to my earlier question on the seach function and layer
> activation.
> GM2.0.1, patched from base MS4W package.
> The search works quite well now, and I have successfully customized the html
> template to display the info I want.
> Now I have a timeout problem, which is sometimes circumvented by increasing the
> php timeout value to 60 seconds (unless someone else uses the mapserver at the
> same time).
> Fatal error: Maximum execution time of 60 seconds exceeded in
> C:\ms4w\apps\geomoose2\htdocs\php\itemquery.php on line 101
> The initial search against one of the shapefiles takes 40 seconds or more. I can
> understand this since there are 180,000 records in that shapefile. I have
> indexed it with shptree.
> However, if I click on one of the other returned records, I have to again wait a
> very similar amount of time, most of which is waiting for the highlighted layer
> to draw. It appears from the user's perspective as if the query is rerun every
> time one clicks on a link in the result list.
> I have set the search function to zoom to first hit.
> Default layers are roads and waterways, they are on unless manually turned off.
> The data I query against are points (water-well locations).
> I completed the following exercise to test:
> Reload map.
> Execute search for a name in the "Owner" field of the large database (~180,000
> records)
> Number of records returned: 22.
> Time to return list of records: 49 seconds.
> Time to draw layers zoomed to first hit: 8 seconds (57 cumulative seconds)
> Time to draw highlighted layer: 56 seconds (113 cumulative seconds).
> Then I clicked on a few of the other results in the list and in each case it
> took 7 seconds to zoom to that result and draw the layers, but 45 additional
> seconds for the highlight layer to appear, during which time the Firefox
> statusbar indicates "Transferring data from [my hostname]...", and at which end
> the statusbar indicates "Done". If there are other requests on the server the
> result appears to be the PSOD, presumably due to the aforementioned timeout
> error.
> Firebug confirms the amount of time that the itemquery.php request takes, but I
> am regrettably largely untrained in the art of deciphering the balance of the
> output.
> Is there enlightenment to be found from the list members on this topic?
> Thanks!
> /Johan.
> Johan Forsman
> Geologist
> Safe Drinking Water Program
> Louisiana Department of Health and Hospitals
> Office of Public Health
> Telephone: 225.342.7309
> Telefax: 225.342.7303
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
