[Geomoose-users] display the results and zoom.
FRANZ OKYERE franzzoa at hotmail.com
Mon Sep 28 16:54:46 EDT 2009
Hi all,  I quit on using processquerytemplate and processtemplate methods. Its just not helpful. I spent too much time on it. I'm rather using mysql to display the results- its perfect. However the layer does not persist when i click on one of the result to zoom to it. Anyone with similar experience or suggestion? Thanks very much.            Franz. GIS Specilist. SIT.
> Date: Mon, 28 Sep 2009 10:26:02 -0600
> From: bfraser at geoanalytic.com
> To: bfischer at houstoneng.com
> CC: geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] map-source;  only 2 valid types?
> Brian,
>    I'd be interested in seeing Google Maps access implemented, and I'd be
> willing to give up printing the Google Maps layer if it meant I could view it on
> the screen.
>    Looking through GM v2's main.js and OpenLayer's google.html example, it
> appears that adding a layer type of "Google" looks simple.  But I'm concerned
> about the projection.  Would it mean that my site would have to use Spherical
> Mercator as the view projection?   Would Dan's recent enhancement of raster
> projection in OpenLayers be useful so I could set a view projection of UTM?  Or
> would performance be a problem?
> Best Regards,
> Brent (the other Brent) Fraser
> Brian Fischer wrote:
> > Brent,
> > These two layer types that are on my wish list to integrate into
> > GeoMOOSE,  as well as Tilecache layer types.  Maybe we could pool some
> > money together to have Dan implement them??  As Dan and I have talked
> > about this in the past the tricky part is whether you need to be able to
> > print these layer types to .pdf.  That requirement would be a much
> > larger effort than just making them viewable.
> > Dan,
> > Met Council just released a new basemap AGS Rest API service for the
> > twin cities.  See snippet from email below.  Jessica did mention she
> > tested this and got it to work with OpenLayers.  It’s pretty nice and
> > sure would be cool to show it can be used in GeoMOOSE!
> > *Metropolitan Council ArcGIS Base Map Services*
> > The Metropolitan Council is making available two cached base map
> > services through ArcGIS Server./ /The Metropolitan Council base map
> > contains common data layers symbolized and shown appropriately for 10
> > scale levels; including roadways, water features, political boundaries,
> > Parks, trails, and land marks.  The base map will be updated as
> > necessary to maintain current data - at least quarterly to allow for
> > MetroGIS municipality and road updates.
> > These services are available for use in within ArcMap, in web
> > applications through use of Rest Services, and as a layer in Google Earth.
> >     * *BaseMap*:  In Web Mercator Projection suitable for use in mashups
> >       with Google Maps.
> >       http://gis.metc.state.mn.us/ArcGIS/rest/services/BaseLayer/BaseMap/MapServer
> >     * *UTMBaseMap*:  Same Features and Symbology as BaseMap above, but
> >       projected for UTM, better for use with other MetroGIS data.
> >       http://gis.metc.state.mn.us/ArcGIS/rest/services/BaseLayer/UTMBaseMap/MapServer
> > *Brian Fischer,* CFM  GIS Project Manager
> > *Houston Engineering, Inc.*
> > Phone: W: 763.493.4522 / M: 763.229.2734
> > *From:* Dan Little [mailto:danlittle at yahoo.com]
> > *Sent:* Wednesday, September 23, 2009 9:56 AM
> > *To:* Brent Lund (ADM); geomoose-users at lists.sourceforge.net
> > *Subject:* Re: [Geomoose-users] map-source; only 2 valid types?
> > Currently unimplemented.  The reason is that the actual requests are
> > managed by GeoMOOSE and require full integration in with the catalog to
> > work correctly.  This simply hasn't happened with those two types yet.
> > ArcGIS93Rest may take a while because I'm not sure anyone has a test
> > server for me to utilize.
> >     *From:* Brent Lund (ADM) <Brent.Lund at state.mn.us>
> >     *To:* "geomoose-users at lists.sourceforge.net"
> >     <geomoose-users at lists.sourceforge.net>
> >     *Sent:* Wednesday, September 23, 2009 9:51:56 AM
> >     *Subject:* [Geomoose-users] map-source; only 2 valid types?
> >     Is the documentation http://www.geomoose.org/moose/docs/mapbook.html
> >     correct in referring to only 2 valid types (mapserver, wms).   Are
> >     other OpenLayers types valid (but undocumented)?   In particular I
> >     am interested in utilizing OpenLayers types Google and ArcGIS93Rest.
> >     Thanks,
> >     Brent
> > Come build with us! The BlackBerry&reg; Developer Conference in SF, CA
> > is the only developer event you need to attend this year. Jumpstart your
> > developing skills, take BlackBerry mobile applications to market and stay
> > ahead of the curve. Join us from November 9&#45;12, 2009. Register now&#33;
> > http://p.sf.net/sfu/devconf
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
_________________________________________________________________
Get the best of MSN on your mobile
http://clk.atdmt.com/UKM/go/147991039/direct/01/
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090928/4886b8cb/attachment.html
More information about the Geomoose-users mailing list
