[Geomoose-users] GM 1.6 Identify subset of layer features
Brent Fraser
bfraser at geoanalytic.com
Wed Dec 1 15:20:51 EST 2010
Brian,
Hmmm. Is the Geomoose mapbook setting <map title="Colleges"? Since
you've got the mapserver layer STATUS ON, the LAYER depends on GeoMoose
turning the layer on (i.e the user turns on the layer by using the
checkbox in the Catalog, and Geomoose passes the list of "visible"
layers to mapserver to do the identify). Or for testing you could just
set STATUS DEFAULT (I never did like ON vs DEFAULT in mapserver, it
seems backwards to me).
Best Regards,
Brent Fraser
On 12/1/2010 1:05 PM, Brian Welch wrote:
> Brent,
> None of the layers in the Identify.map file have a CLASS section. Is
> that allowed in the Identify.map file?
> I tried the following, but no results appeared for the college layer
> (just the underlying parcel layer) when using the Identify tool:
> This is the LAYER definition I inserted into the Identify.map file -
> didn't seem like as STYLE block would be needed:
> LAYER # Colleges Polygon Layer
> NAME 'Colleges'
> DATA './landrecords/RiceCo_parcelsUTM.shp'
> STATUS ON
> TYPE POLYGON
> METADATA
> qstring_validation_pattern '.'
> END
> CLASSITEM 'DEEDHOLD'
> TEMPLATE './landrecords/identify_Colleges.html'
> TOLERANCE 0
> CLASS
> NAME "Colleges"
> EXPRESSION /ST OLAF COLLEGE*/
> END
> END
> Any thoughts?
> Thanks.
> Brian
> Brian Welch, GIS Technician
> City of Northfield
> Northfield, MN 55057
> 507-645-3027
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101201/1195cfac/attachment.html
More information about the Geomoose-users
