[Geomoose-users] GM 1.6 Identify subset of layer features
    Brent Fraser
    bfraser at geoanalytic.com
    Wed Dec  1 16:10:58 EST 2010
What happens if you set the STATUS OFF for both the parcel layers?  Your
config should work; I'll have to do a little more digging...
Best Regards,
Brent Fraser
On 12/1/2010 1:59 PM, Brian Welch wrote:
> Thanks Brent,
> My experience with GM 1.6 is that white spaces in layer names kills
> the Identify process, even if the names in the XML file match the
> layer map file and the Identify.map layer name. My workaround has been
> to use underscores for any layers that provide feedback with the
> Identify tool. It's been a useful way to cue the users that the layer
> is "Identifiable".
> Since I have many layers in my Identify. map file I've pasted just the
> two that correspond to the parcels and the colleges (see below message
> text). Note that both refer to the same shapefile that contains all of
> the parcels for the region. I don't want to eliminate the college
> parcels in the generic parcel file since the college layer is one that
> is off by default (and it's off the Identify tool returns only results
> for the generic parcel layer). Likewise I wouldn't want to eliminate
> the college parcels from the generic parcel Identify.map layer since
> that would still return parcel-specific information.
> My goal is to allow interested users to turn on the college layer and
> then be able to click college-owned parcels to see additional
> information related to the college. I don't mind that both the college
> and generic parcel information shows up in the Information tab (that's
> actually a good thing!). I just don't want the college data to show up
> for the non-college parcels, even if the college layer is turned on.
> I had hoped that it would be possible to utilize the underlying
> generic parcel data for both, but it looks like I'll have to export a
> separate shapefile for the college overlay in order to get the
> Identify to differentiate between the underlying parcels and the
> college parcels. Unless anyone has a new suggestion...
> Thanks!
> Brian
>  LAYER # Rice Co. Parcels Polygon Layer
>   NAME 'RiceCo_Parcels'
>   DATA 'landrecords/RiceCo_parcelsUTM.shp'
>   STATUS ON
>   TYPE POLYGON
>   METADATA
>   qstring_validation_pattern '.'
>   END
>   TEMPLATE 'landrecords/identify_RCparcel.html'
>   TOLERANCE 0
>  END
>  LAYER # Colleges Polygon Layer
>   NAME 'Colleges'
>   DATA './landrecords/RiceCo_parcelsUTM.shp'
>   STATUS ON
>   TYPE POLYGON
>   METADATA
>   END
>   CLASSITEM 'DEEDHOLD'
>   TEMPLATE './landrecords/identify_Colleges.html'
>   TOLERANCE 0
>   CLASS
>    EXPRESSION /*COLLEGE/
>   END
>  END
> Brian Welch, GIS Technician
> City of Northfield
> Northfield, MN 55057
> 507-645-3027
> >>> Brent Fraser <bfraser at geoanalytic.com> 12/1/2010 2:37 PM >>>
> I think GM 1.6 strips the spaces before passing the layer names to
> mapserver.  So in theory you could have a map title of "My Colleges"
> in the mapbook and a layer with a name of MyColleges in the mapserver
> map file.
> As for the results problem, it's difficult to say without seeing the
> entire identify.map (and the <map> defs in the mapbook), but I'd guess
> you have two layers in your indentify.map: one for college parcels and
> one for other parcels.  You need to have a class in the the other
> parcels layer that does not include colleges (basically negate the
> expression in the college layer)
> Best Regards,
> Brent Fraser
> On 12/1/2010 1:18 PM, Brian Welch wrote:
>> Some bug-checking did catch a white space in my layer name in the XML
>> file. That's now been fixed with an underscore so all the layer
>> references match: XML file, layer map file and Identify.map file. I
>> get the appropriate Identify results to appear, but they appear for
>> ALL parcels, not just the college parcels. The attempt to add an
>> expression that I pasted in my previous post had no effect on the
>> results: the college data appears for Identify queries of ANY parcel.
>> Is there a way to get the Identify query to mirror the expression
>> used to create the layer?
>> Thanks.
>> Brian
>> City of Northfield
>> 507-645-3027
>> >>> Brent Fraser <bfraser at geoanalytic.com> 12/1/2010 11:31 AM >>>
>> Brian,
>>   Couldn't you just use the same layer definition in your
>> identify.map as you use in your display layer?
>> Best Regards,
>> Brent Fraser
>> On 12/1/2010 8:53 AM, Brian Welch wrote:
>>> I'm using Geomoose v1.6
>>> I have a layer in my application that shows a subset of parcels
>>> (local college-owned land). The mapping layer in GM uses a simple
>>> expression based on the property owner's name to map just those
>>> properties owned by the colleges.
>>> I'd like to create an appropriate layer in the Identify.map file
>>> that will act only on that subset in order to display specific
>>> information related to the colleges. However, I don't want the
>>> college information to show up for all parcels in town. Is there
>>> some way to replicate the expression that I use in the CLASS call of
>>> the mapping file to get the LAYER in the Identify.map file to act
>>> only the college-owned parcels? I can't figure out whether the
>>> qstring_validation_pattern is where I should focus, and if so, what
>>> is the appropriate query syntax? The field name is [DEEDHOLD] and
>>> the query value would be "*COLLEGE" (note the need for a wildcard to
>>> pick up both colleges in town).
>>> I'd like to know if this is possible by modifying the Identify.map
>>> layer with an appropriate query or whether I should just take the
>>> easy way out and create a separate shapefile of college-owned parcels.
>>> Thanks.
>>> Brian
>>> City of Northfield
>>> 507-645-3027
>>> Increase Visibility of Your 3D Game App&  Earn a Chance To Win $500!
>>> Tap into the largest installed PC base&  get more eyes on your game by
>>> optimizing for Intel(R) Graphics Technology. Get started today with the
>>> Intel(R) Software Partner Program. Five $500 cash prizes are up for grabs.
>>> http://p.sf.net/sfu/intelisp-dev2dev
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.sourceforge.net
>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101201/9aa94fd8/attachment.html
More information about the Geomoose-users
