Here's the trick I use in the Mapbook to take care of this:
<!-- A trick because the ful extent has to be bigger than what we want to show to get the met council tiles, so make full extent call initial extent instead
<tool name="fullextent" title="Zoom to Full Extent" type="internal" action="fullextent" selectable="false"/> -->
<tool name="fullextent" title="Zoom to Initial Extent" type="javascript" selectable="false" >
Map.zoomToExtent(OpenLayers.Bounds.fromArray(CONFIGURATION.initial_extent));
</tool>
This will allow you to increase the fullextent and have the "zoom to full extent" tool use the initial extent.
Len
From: Johnson, Jeremy [mailto:JJohnson at ci.blaine.mn.us]
Sent: Tuesday, December 21, 2010 11:15 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Initial and Max Extent
In changing my MAX_EXTENT in the mapbook, it seems to also be limiting the amount data sent from Met Council Base Map. I would like to have that base layer image stretch beyond my initial extent, but I want my max_extent to be equal to my inital extent. Make sense?
Jeremy Johnson, GISP
G.I.S. Coordinator
City of Blaine
10801 Town Square Dr Ne
Blaine, MN 55449
(763) 717-2639
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101221/6500d034/attachment.html
