[Geomoose-users] Initial and Max Extent
Johnson, Jeremy
JJohnson at ci.blaine.mn.us
Tue Dec 21 14:15:42 EST 2010
Perfect Len. Thank you so much. Worked perfectly.
Jeremy Johnson, GISP
City of Blaine
Sent: Tuesday, December 21, 2010 12:42 PM
To: Johnson, Jeremy; geomoose-users at lists.sourceforge.net
Subject: RE: Initial and Max Extent
Here's the trick I use in the Mapbook to take care of this:
<!-- A trick because the ful extent has to be bigger than what we want
to show to get the met council tiles, so make full extent call initial
extent instead
<tool name="fullextent" title="Zoom to
Full Extent" type="internal" action="fullextent" selectable="false"/>
Initial Extent" type="javascript" selectable="false" >
Map.zoomToExtent(OpenLayers.Bounds.fromArray(CONFIGURATION.initial_exten
t));
</tool>
This will allow you to increase the fullextent and have the "zoom to
full extent" tool use the initial extent.
Len
From: Johnson, Jeremy [mailto:JJohnson at ci.blaine.mn.us]
Sent: Tuesday, December 21, 2010 11:15 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Initial and Max Extent
In changing my MAX_EXTENT in the mapbook, it seems to also be limiting
the amount data sent from Met Council Base Map. I would like to have
that base layer image stretch beyond my initial extent, but I want my
max_extent to be equal to my inital extent. Make sense?
G.I.S. Coordinator
City of Blaine
10801 Town Square Dr Ne
Blaine, MN 55449
(763) 717-2639
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101221/353a092c/attachment.html
More information about the Geomoose-users
