[Geomoose-users] Identify Service Issue
Brian Fischer
bfischer at houstoneng.com
Wed Dec 22 16:55:14 EST 2010
Two things to try. My guess is the latter is the real issue.
1) Add a TOLERANCE 0 to the layer definition in the mapfile since it is a polygon layer.
2) Your layer name in the mapbook doesn't match your layer name in the mapfile.
See changes below.
Brian Fischer, CFM GIS Manager
Houston Engineering, Inc.
Phone: Direct: 763-493-6664 / W: 763.493.4522 / M: 763.229.2734
From: Johnson, Jeremy [mailto:JJohnson at ci.blaine.mn.us]
Sent: Wednesday, December 22, 2010 3:23 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Identify Service Issue
I have been scouring past emails from the list and can't seem to find a solution to my issue. I have added my own parcel layer and have been succesful in having the identify tool work exactly how I want it. However, if I add another layer and want to identify that layer, all that is returned is the ground coordinates of the click. Below is the pertinient information. Any help would be greatly appreciated.
MAPFILE
MAP
NAME 'blocks'
SIZE 800 650
STATUS ON
EXTENT 479000 4996100 488810 5006500
UNITS METERS
INCLUDE "../../geomoose_globals.map"
PROJECTION
'init=epsg:26915'
END
LAYER
NAME blocks
DATA '/ms4w/data/blaine_block_utm.shp'
STATUS DEFAULT
TYPE POLYGON
TOLERANCE 0
CLASS
NAME 'Census Blocks'
STYLE
SYMBOL 'plainline'
SIZE 2
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
END
METADATA
'identify_record' 'identify_blocks.html'
END
END
END ## end Map
IDENTIFY_BLOCKS.HTML
<!-- MapServer Template -->
<tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Parcels</u></b></tr>
<tr>
<td align="right"><b>STFID:</b></td>
<td>[STFID]</td>
</tr>
<tr>
<td align="left"><u>Population:</u></td>
<td>[POP2000]</td>
</tr>
<tr><td colspan="2"><hr></td></tr>
MAPBOOK ENTRIES
<map-source name="blocks" type="mapserver">
<file>./blaine/census/blocks.map</file>
<layer name="blocks"/>
</map-source>
______________________________________________________________________________
<service name="identify" title="Identify" display="false">
<url>php/identify.php</url>
<step type="spatial" name="shape" line="false" polygon="false" jump-start="true" default="point">
<input type="visiblelayers" name="layers"/>
</step>
</service>
<layer title="Blaine Census Blocks" src="blocks/blocks" status="off" popups="true" />
Jeremy Johnson, GISP
G.I.S. Coordinator
City of Blaine
10801 Town Square Dr Ne
Blaine, MN 55449
(763) 717-2639
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101222/da5e1c93/attachment.html
More information about the Geomoose-users
