[Geomoose-users] Identify Service Issue
    Johnson, Jeremy
    JJohnson at ci.blaine.mn.us
    Wed Dec 22 16:58:14 EST 2010
Thanks Brian - Your second suggestion was the issue.
Jeremy Johnson, GISP
City of Blaine
From: Brian Fischer [mailto:bfischer at houstoneng.com]
Sent: Wednesday, December 22, 2010 3:55 PM
To: Johnson, Jeremy; geomoose-users at lists.sourceforge.net
Subject: RE: Identify Service Issue
Two things to try.  My guess is the latter is the real issue.
1)      Add a TOLERANCE 0 to the layer definition in the mapfile since
it is a polygon layer.
2)      Your layer name in the mapbook doesn't match your layer name in
the mapfile.
See changes below.
Brian Fischer, CFM  GIS Manager
Houston Engineering, Inc.
Phone: Direct: 763-493-6664 / W: 763.493.4522 / M: 763.229.2734
From: Johnson, Jeremy [mailto:JJohnson at ci.blaine.mn.us]
Sent: Wednesday, December 22, 2010 3:23 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Identify Service Issue
I have been scouring past emails from the list and can't seem to find a
solution to my issue.  I have added my own parcel layer and have been
succesful in having the identify tool work exactly how I want it.
However, if I add another layer and want to identify that layer, all
that is returned is the ground coordinates of the click.  Below is the
pertinient information.  Any help would be greatly appreciated.
MAPFILE
	MAP
	 NAME 'blocks'
	 SIZE 800 650
	 STATUS ON
	 EXTENT  479000 4996100 488810 5006500
	 UNITS METERS
	 INCLUDE "../../geomoose_globals.map"
	 PROJECTION
	  'init=epsg:26915'
	 END
	   LAYER
	         NAME blocks
	         DATA '/ms4w/data/blaine_block_utm.shp'
	         STATUS DEFAULT
	         TYPE POLYGON
	                TOLERANCE 0
	            CLASS
	           NAME 'Census Blocks'
	           STYLE
	             SYMBOL 'plainline'
	             SIZE 2
	             COLOR -1 -1 -1
	             OUTLINECOLOR 255 0 0
	              END
	         END
	  METADATA
	        'identify_record' 'identify_blocks.html'
	  END
	     END
	END ## end Map
IDENTIFY_BLOCKS.HTML
	<!-- MapServer Template -->
	<tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Parcels</u></b></tr>
	<tr>
	<td align="right"><b>STFID:</b></td>
	<td>[STFID]</td>
	</tr>
	<tr>
	<td align="left"><u>Population:</u></td>
	<td>[POP2000]</td>
	</tr>
	<tr><td colspan="2"><hr></td></tr>
MAPBOOK ENTRIES
	 <map-source name="blocks" type="mapserver">
	  <file>./blaine/census/blocks.map</file>
	  <layer name="blocks"/>
	 </map-source>
________________________________________________________________________
______
	 <service name="identify" title="Identify" display="false">
	  <url>php/identify.php</url>
	  <step type="spatial" name="shape" line="false" polygon="false"
jump-start="true" default="point">
	   <input type="visiblelayers" name="layers"/>
	  </step>
	 </service>
______
	  <layer title="Blaine Census Blocks" src="blocks/blocks"
status="off" popups="true" />
G.I.S. Coordinator
City of Blaine
10801 Town Square Dr Ne
Blaine, MN  55449
(763) 717-2639
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101222/22f9922f/attachment.html
More information about the Geomoose-users
