[Geomoose-users] getting started, running the demos question
Dan Little
danlittle at yahoo.com
Mon Jan 4 09:41:46 EST 2010
I think we simply need to do more testing on the more bleeding edge software. In some regard, we have enough issues keeping up with browser changes. Moving past developer excuses, I'm running OS/X 10.5.something and a few variants of debian and I believe they all have PHP 5.2, which is why there is probably some quirks when moving to PHP 5.3.
Brian/Len/Brent, any help on your versions? I just really don't use Windows for anything but running IE...
>From: John Callahan <john.callahan at udel.edu>
>To: geomoose-users at lists.sourceforge.net
>Sent: Sun, January 3, 2010 8:31:42 AM
>Subject: [Geomoose-users] getting started, running the demos question
>>I'm trying to setup GeoMoose but ran into a problem that I'm not sure how to fix. After several hours of modifying my environment, here's where I'm at now:
>Windows OS
>Apache 2.2.11
>>PHP 5.3.1 (VC6 x86 Thread Safe (2009-Nov-19 10:20:08) from http://windows.php.net/download/)
>MapServer 5.4.2 with PHP_MapScript from ms4w_3.0_beta7 2009-09-01 (http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL_3.0.html)
>GeoMoose from moose2-trunk as downloaded from the tarball as of Jan 1. ( I choose this over the 2.0.1 release because I liked some of the changes in 2.2.)
>Apparently, the php dl() function is now deprecated as of PHP 5.3. Even with the enable_dl set to 'On' in php.ini, it still throws an error when trying to run the demo. GeoMoose uses this function. How can I get around that?
>Also, I see GeoMoose uses php_dbase extension. That dll is not in the PHP or MS4W distributions I downloaded. I did see a php_ogr dll in MW4W though. How can I get around this?
>Lastly, I tried using php 5.2.8 and I WAS able to get the GeoMoose demo mostly working. However, some problems were occurring, likely because I didn't have php_mapscript, or maybe a wrong version. I switched to php 5.3 because I couldn't find a php_mapscript for MapServer 5.4.2 for php 5.2.x and because it was what MS4W currently supports.
>Thanks for any help or thoughts.
>- John
>John Callahan, Geospatial Application Developer
>Delaware Geological Survey, University of Delaware
>>URL: http://www.dgs.udel.edu
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100104/c622c107/attachment.html
More information about the Geomoose-users
