[Geomoose-users] getting started, running the demos question
Brent Fraser
bfraser at geoanalytic.com
Mon Jan 4 10:39:23 EST 2010
Dan, John,
I agree; we need to test GM 2.2 with MS4W 3.0. I'll have a look at the beta.
I see that PHP's dl() is deprecated (due to security and threading issues), but
the doc doesn't say what the replacement is (use the PHP.ini?). I think our
plan would be to modify config.php to test if a module is loaded (as it does
now) and just give a message if it isn't:
if(!extension_loaded('gd') && !extension_loaded('gd2')) {
printf( 'Please ensure the following extension is loaded using
php.ini:'.'php_gd2.'.PHP_SHLIB_SUFFIX);
Unless there's a better way?
As for the php.dbase.dll, we could ask the MS4W people to include it...
Best Regards,
Brent Fraser
Dan Little wrote:
> I think we simply need to do more testing on the more bleeding edge
> software. In some regard, we have enough issues keeping up with browser
> changes. Moving past developer excuses, I'm running OS/X
> 10.5.something and a few variants of debian and I believe they all have
> PHP 5.2, which is why there is probably some quirks when moving t o PHP 5.3.
> Brian/Len/Brent, any help on your versions? I just really don't use
> Windows for anything but running IE...
> *From:* John Callahan <john.callahan at udel.edu>
> *To:* geomoose-users at lists.sourceforge.net
> *Sent:* Sun, January 3, 2010 8:31:42 AM
> < b>Subject: [Geomoose-users] getting started, running the demos
> question
> I'm trying to setup GeoMoose but ran into a problem that I'm not
> sure how to fix. After several hours of modifying my environment,
> here's where I'm at now:
> Windows OS
> Apache 2.2.11
> PHP 5.3.1 (VC6 x86 Thread Safe (2009-Nov-19 10:20:08) from
> http://windows.php.net/download/)
> MapServer 5.4.2 with PHP_MapScript from ms4w_3.0_beta7 2009-09-01
> (http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL_3.0.html)
> GeoMoose from moose2-trunk as downloaded from the tarball as of Jan
> 1. ( I choose this over the 2.0.1 release because I liked some of
> the changes in 2.2.)
> Apparently, the php dl() function is now deprecated as of PHP 5.3.
> Even with the enable_dl set to 'On' in php.ini, it still throws an
> error when trying to run the demo. GeoMoose uses this function.
> How can I get around that?
> Also, I see GeoMoose uses php_dbase extension. That dll is not in
> the PHP or MS4W distributions I downloaded. I did see a php_ogr dll
> in MW4W though. How can I get around this?
> Lastly, I tried using php 5.2.8 and I WAS able to get the GeoMoose
> demo mostly working. However, some problems were occurring, likely
> because I didn't have php_mapscript, or maybe a wrong version. I
> switched to php 5.3 because I couldn't find a php_mapscript for
> MapServer 5.4.2 for p hp 5.2.x and because it was what MS4W
> currently supports.
> Thanks for any help or thoughts.
> - John
> John Callahan, Geospatial Application Developer
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> This SF.Net email is sponsored by the Verizon Developer Community
> Take advantage of Verizon's best-in-class app development support
> A streamlined, 14 day to market process makes app distribution fast and easy
> Join now and get one step closer to millions of Verizon customers
> http://p.sf.net/sfu/verizon-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
