[Geomoose-users] getting started, running the demos question
John Callahan
john.callahan at udel.edu
Mon Jan 4 11:01:07 EST 2010
Thanks Dan/Brent.
Would you say that GeoMoose 2.2 would be tested/modified to work with
MapServer 5.4.x and PHP 5.3 (and therefore MS4W 3.0 from a Windows
perspective)? Actually, GM 2.2 could probably work for all MapServer 5.x
versions....
And that GeoMoose 2.0.x works with MapServer 5.2.x and PHP 5.2 (and
therefore MS4W 2.3.x)?
I wouldn't mind using GM 2.2 with PHP 5.2 (at least temporarily) if I can
find a php_mapscript dll based on PHP 5.2 that works with MapServer 5.4.2.
- John
On Mon, Jan 4, 2010 at 10:39 AM, Brent Fraser <bfraser at geoanalytic.com>wrote:
> Dan, John,
> I agree; we need to test GM 2.2 with MS4W 3.0. I'll have a look at the
> beta.
> I see that PHP's dl() is deprecated (due to security and threading issues),
> but the doc doesn't say what the replacement is (use the PHP.ini?). I think
> our plan would be to modify config.php to test if a module is loaded (as it
> does now) and just give a message if it isn't:
> if(!extension_loaded('gd') && !extension_loaded('gd2')) {
> printf( 'Please ensure the following extension is loaded using
> php.ini:'.'php_gd2.'.PHP_SHLIB_SUFFIX);
> Unless there's a better way?
> As for the php.dbase.dll, we could ask the MS4W people to include it...
> Best Regards,
> Brent Fraser
> Dan Little wrote:
>> I think we simply need to do more testing on the more bleeding edge
>> software. In some regard, we have enough issues keeping up with browser
>> changes. Moving past developer excuses, I'm running OS/X 10.5.something
>> and a few variants of debian and I believe they all have PHP 5.2, which is
>> why there is probably some quirks when moving t o PHP 5.3.
>> Brian/Len/Brent, any help on your versions? I just really don't use
>> Windows for anything but running IE...
>> *From:* John Callahan <john.callahan at udel.edu>
>> *To:* geomoose-users at lists.sourceforge.net
>> *Sent:* Sun, January 3, 2010 8:31:42 AM
>> < b>Subject: [Geomoose-users] getting started, running the demos
>> question
>> I'm trying to setup GeoMoose but ran into a problem that I'm not
>> sure how to fix. After several hours of modifying my environment,
>> here's where I'm at now:
>> Windows OS
>> Apache 2.2.11
>> PHP 5.3.1 (VC6 x86 Thread Safe (2009-Nov-19 10:20:08) from
>> http://windows.php.net/download/)
>> MapServer 5.4.2 with PHP_MapScript from ms4w_3.0_beta7 2009-09-01
>> (http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL_3.0.html
>> GeoMoose from moose2-trunk as downloaded from the tarball as of Jan
>> 1. ( I choose this over the 2.0.1 release because I liked some of
>> the changes in 2.2.)
>> Apparently, the php dl() function is now deprecated as of PHP 5.3.
>> Even with the enable_dl set to 'On' in php.ini, it still throws an
>> error when trying to run the demo. GeoMoose uses this function. How
>> can I get around that?
>> Also, I see GeoMoose uses php_dbase extension. That dll is not in
>> the PHP or MS4W distributions I downloaded. I did see a php_ogr dll
>> in MW4W though. How can I get around this?
>> Lastly, I tried using php 5.2.8 and I WAS able to get the GeoMoose
>> demo mostly working. However, some problems were occurring, likely
>> because I didn't have php_mapscript, or maybe a wrong version. I
>> switched to php 5.3 because I couldn't find a php_mapscript for
>> MapServer 5.4.2 for p hp 5.2.x and because it was what MS4W
>> currently supports.
>> Thanks for any help or thoughts.
>> - John
>> John Callahan, Geospatial Application Developer
>> Delaware Geological Survey, University of Delaware
>> URL: http://www.dgs.udel.edu
>> This SF.Net email is sponsored by the Verizon Developer Community
>> Take advantage of Verizon's best-in-class app development support
>> A streamlined, 14 day to market process makes app distribution fast and
>> easy
>> Join now and get one step closer to millions of Verizon customers
>> http://p.sf.net/sfu/verizon-dev2dev
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100104/92227672/attachment.html
More information about the Geomoose-users
