[Geomoose-users] Mr SID images...one problem solved...another crops up
TC Haddad tchaddad at gmail.com
Mon Oct 4 12:46:35 EDT 2010
A TILEINDEX layer in mapserver a simple shapefile showing the outlines of
your images, that has a field containing a path to each image on your disk.
can you confirm that the paths in your TILEINDEX lead to the correct place?
You might want to use the
-write_absolute_path
option in gdaltindex to make sure that the photos are able to be found by
mapserver. Also make sure you are specifying the correct name in your LAYER
definition for the shapefile field that contains the path to the images
Tanya
On Mon, Oct 4, 2010 at 9:37 AM, Bill Harbour <bharbour at bcbe.org> wrote:
 The problem I had with the aerials only drawing with only 256 colors was
> that I was using GIF output.  To solve that problem I switched to JPEG
> output with RGB in the mapfile.  Now the aerials display perfectly.
> Here’s that corrected part of the mapfile…
> IMAGETYPE jpeg
>   OUTPUTFORMAT
>       NAME jpeg
>       DRIVER "GD/JPEG"
>       MIMETYPE "image/jpeg"
>       IMAGEMODE RGB
>       EXTENSION "jpg"
>   END
> Now I have another problem.  I have eight Mr SID images that cover the
> county.  I used gdaltindex to create a tile index and put that into my
> mapfile as a single layer.  That tiled layer now gives me a pink screen when
> I turn it on.  The individual raster display just fine.
> Does anyone have any experience in getting the raster tile index to display
> properly in Geomoose?
> Tnx,
> Baldwin County Public Schools
> Bill Harbour
> GIS Coordinator
> Information Technology Services
> Baldwin County Board of Education
> 1071* * B Ave
> Loxley, AL 36551
> V 251-580-1916
> F 251-972-6851
> Office 251-972-6850
> http://www.bcbe.org
> *"When life gets too unreal, sit down with a good book."* - Garrison
> Keillor
> Virtualization is moving to the mainstream and overtaking non-virtualized
> environment for deploying applications. Does it make network security
> easier or more difficult to achieve? Read this whitepaper to separate the
> two and get a better understanding.
> http://p.sf.net/sfu/hp-phase2-d2d
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101004/3185bc82/attachment.html
More information about the Geomoose-users mailing list
