[Geomoose-users] Mr SID images...one problem solved...another crops up
Bill Harbour bharbour at bcbe.org
Mon Oct 4 12:50:58 EDT 2010
Tonya:
Yes...I used the -write_absolute_path option.  The location field is LOCATION which is the default.  Dunno?!?!?!
Thanks,
Baldwin County Public Schools
Bill Harbour
GIS Coordinator
Information Technology Services
Baldwin County Board of Education
1071  B Ave
Loxley, AL 36551
V 251-580-1916
F 251-972-6851
Office 251-972-6850
bharbour at bcbe.org<mailto:bharbour at bcbe.org>
http://www.bcbe.org
"When life gets too unreal, sit down with a good book." - Garrison Keillor
Sent: Monday, October 04, 2010 11:47 AM
To: Bill Harbour
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Mr SID images...one problem solved...another crops up
A TILEINDEX layer in mapserver a simple shapefile showing the outlines of your images, that has a field containing a path to each image on your disk.
can you confirm that the paths in your TILEINDEX lead to the correct place? You might want to use the
option in gdaltindex to make sure that the photos are able to be found by mapserver. Also make sure you are specifying the correct name in your LAYER definition for the shapefile field that contains the path to the images
Tanya
On Mon, Oct 4, 2010 at 9:37 AM, Bill Harbour <bharbour at bcbe.org<mailto:bharbour at bcbe.org>> wrote:
The problem I had with the aerials only drawing with only 256 colors was that I was using GIF output.  To solve that problem I switched to JPEG output with RGB in the mapfile.  Now the aerials display perfectly.
Here's that corrected part of the mapfile...
IMAGETYPE jpeg
  OUTPUTFORMAT
      NAME jpeg
      DRIVER "GD/JPEG"
      MIMETYPE "image/jpeg"
      IMAGEMODE RGB
      EXTENSION "jpg"
  END
Now I have another problem.  I have eight Mr SID images that cover the county.  I used gdaltindex to create a tile index and put that into my mapfile as a single layer.  That tiled layer now gives me a pink screen when I turn it on.  The individual raster display just fine.
Does anyone have any experience in getting the raster tile index to display properly in Geomoose?
Tnx,
Bill Harbour
GIS Coordinator
1071  B Ave
Loxley, AL 36551
V 251-580-1916
F 251-972-6851
Office 251-972-6850
http://www.bcbe.org
Virtualization is moving to the mainstream and overtaking non-virtualized
environment for deploying applications. Does it make network security
easier or more difficult to achieve? Read this whitepaper to separate the
two and get a better understanding.
http://p.sf.net/sfu/hp-phase2-d2d
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net<mailto:Geomoose-users at lists.sourceforge.net>
https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101004/c81e9c6f/attachment.html
More information about the Geomoose-users mailing list
