[Geomoose-users] Add New Customer Calling Service
Dan Little danlittle at yahoo.com
Thu Dec 1 12:15:48 EST 2011
That's actually pretty easy, it's just modifying the select service and maybe writing a custom PHP script to output a file that the call system likes (say a CSV file with the name and phone number properly formatted).
I'd estimate it at something like 8-hours to get familiar with the data file, setup some carto, and then either configure select.php, and write the custom output script.  That would assume a known setup application.
>________________________________
> From: Ed Boesenberg <eboesenberg at niraengineers.com>
>To: geomoose-users at lists.osgeo.org
>Sent: Thursday, December 1, 2011 10:42 AM
>Subject: [Geomoose-users] Add New Customer Calling Service
>I had seen a function on an ArcGIS Server based application and was wondering if an equal service could be possible using GeoMoose.
>The function of the service would be to call water service customers based on a query in GeoMoose.  For example, there will be a water supply outage along Main Street because of water crews doing some type of work, the user would start up GeoMoose which has a point layer representing each customer and contact information, then the user would draw a polygon around the main street area, then GeoMoose would gather all the customers within the polygon and would spit out a file to some other phone hardware which would in turn start calling each customer with a prerecorded message.
>Has anyone setup anything like this before?
>What would the ball park cost be?
>Thanks,
>Ed
>_______________________________________________
>Geomoose-users mailing list
>Geomoose-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111201/4633f526/attachment.html
More information about the Geomoose-users mailing list
