[Geomoose-users] Printing reprojected wms layers - GM 2.2
Brent Fraser
bfraser at geoanalytic.com
Tue May 24 13:29:00 EDT 2011
Is this related to
http://sourceforge.net/mailarchive/message.php?msg_id=25045037
Best Regards,
Brent Fraser
On 5/24/2011 11:03 AM, Mark Volz wrote:
> Brent,
> I doubt that the WMS server is problem. First, I am using the 2010
> Minnesota air photos from LMIC which in my opinion is quite robust.
> Next, When using the same server, and map size on a GeoMOOSE
> application that does not use reprojection I have no trouble with
> printing. Last, I have no issues with printing when I have mapserver
> reproject the same wms layer.
> The current mapsize that I am using in my print output about 8 by 9.
> I even tested using a 1 by 1 map at standard quality. Still no luck.
> Mark Volz
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Tuesday, May 24, 2011 10:17 AM
> *To:* Mark Volz
> *Cc:* geomoose-users at lists.sourceforge.net
> *Subject:* Re: [Geomoose-users] Printing reprojected wms layers - GM 2.2
> Mark,
> It could be an image size limitation set by the WMS server. What's
> your page size?
> Best Regards,
> Brent Fraser
> On 5/17/2011 7:31 AM, Mark Volz wrote:
> Hello,
> I added a reprojected wms layer to my map. The map displays fine when
> I am browsing within Geomoose. However, the wms layer does not print.
> Is there any known issues / fixes with printing reprojected wms layers?
> Thanks
> Mark Volz
> Achieve unprecedented app performance and reliability
> What every C/C++ and Fortran developer should know.
> Learn how Intel has extended the reach of its next-generation tools
> to help boost performance applications - inlcuding clusters.
> http://p.sf.net/sfu/intel-dev2devmay
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net <mailto:Geomoose-users at lists.sourceforge.net>
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110524/5d4beaca/attachment.html
More information about the Geomoose-users
