[Geomoose-users] no he logrado identificar capas
Eli Adam
eadam at co.lincoln.or.us
Tue Nov 22 14:46:26 EST 2011
Carlos,
On Tue, Nov 22, 2011 at 11:01 AM, Carlos Alberto Pereira Urrutia <
carlosp.sistemas at gmail.com> wrote:
> Hey; Thanks if that is my question.
> Using the tool identify I get this error:
> Fatal error: Call to undefined function ms_shapeObjFromWkt () in
> C:\ms4w\apps\geomoose2\htdocs\php\identify.php on line 83
> to correct the errors above follows the same;
This error could be from the version of MS4W that you are using. Try a
newer version, 3+, http://maptools.org/ms4w/index.phtml?page=downloads.html
To use a more recent version of MS4W and GeoMoose 2.4, you might need to
make some revisions. In geomoose_globals.map change:
OUTPUTFORMAT
NAME 'agg/jpeg'
DRIVER GD/JPEG #need to change GD-->AGG
To:
OUTPUTFORMAT
NAME 'agg/jpeg'
DRIVER AGG/JPEG #changed from AGG from GD
In symbol.sym comment out or change from:
GAP 10 #GAP is a problem
STYLE 5 5 END #STYLE is a problem as well
To:
#GAP 10 #GAP is a problem
#STYLE 5 5 END #STYLE is a problem as well
> I nor is English and use the same translator.
> Thank you
The translator seems to be working.
Best Regards, Eli
> 2011/11/22 Eli Adam <eadam at co.lincoln.or.us>
>> Carlos,
>> Guessing from an online translator program
>> (http://www.microsofttranslator.com/) I think that your question is:
>> I have a problem at the time of identifying the attributes in the
>> selected layers not is what will be the problem
>> I looked at your site, using firebug
>> (https://addons.mozilla.org/en-US/firefox/addon/firebug/) and noticed
>> a few things:
>> I don't get a map loaded. Do you get a map? MapServer seems to be
>> working by this:
>> http://www.corpoboyaca.gov.co:81/cgi-bin/mapserv.exe?map=/ms4w/apps/geomoose2/maps/corpoboyaca/cb_map/provincias.map&layers=all&mode=map
>> Services.startService is not a function
>> [Break On This Error] Services.startService(serviceName); -compiled.js
>> line 2617
>> "NetworkError: 404 Not Found -
>> http://www.corpoboyaca.gov.co:81/geomoose2/proj4js/lib/defs/EPSG3116.js"
>> Try deleting two
>> 2011/11/22 Carlos Alberto Pereira Urrutia <carlosp.sistemas at gmail.com>:
>> > tengo un problema al momento de identificar los atributos en las capas
>> > seleccionadas no se cual sera el problema
>> > www.corpoboyaca.gov.co:81/geomoose2/corpoboyaca.html
>> > CARLOS A.
>> > Cel 3102645910
>> > AVISO LEGAL: Este mensaje es confidencial y puede contener información
>> > privilegiada la cual no puede ser usada ni divulgada a personas
>> distintas de
>> > su destinatario. Esta prohibida la retención, grabación, utilización,
>> > aprovechamiento o divulgación con cualquier propósito. Si por error
>> recibe
>> > este mensaje, por favor destruya su contenido y avise a su remitente.
>> > _______________________________________________
>> > Geomoose-users mailing list
>> > Geomoose-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
> CARLOS A.
> Cel 3102645910
> privilegiada la cual no puede ser usada ni divulgada a personas distintas
> de su destinatario. Esta prohibida la retención, grabación, utilización,
> aprovechamiento o divulgación con cualquier propósito. Si por error recibe
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111122/cfa8568f/attachment-0001.html
More information about the Geomoose-users
