[Geomoose-users] Select returning too many results
Dan Little
danlittle at yahoo.com
Fri Jul 27 08:57:58 PDT 2012
We had found a similar bug during testing but we thought we got it. There are some quirks (bugs?) with the MapServer 6.0 querying that were not present in the older versions.
Do you happen to have a specific test case that works consistently to produce the bad result?
>________________________________
> From: "Bistrais, Bob" <Bob.Bistrais at maine.gov>
>To: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>Sent: Friday, July 27, 2012 10:43 AM
>Subject: [Geomoose-users] Select returning too many results
>I’m having some trouble with the Select Features tool/select.php in GM 2.6. Sometimes it works fine, but at other times it returns too many results listed in the Found Shapes column, and also, too many shapes are highlighted. I am using pretty much default code, other than changing the layer names and items. I have a 0 buffer set. At first I thought I was drawing a shape too close to a boundary, but on closer inspection, this does not appear to be the case. Any ideas?
>_______________________________________________
>Geomoose-users mailing list
>Geomoose-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120727/039492c0/attachment.html>
More information about the Geomoose-users
