[Geomoose-users] print issues in GM 2.4
Andrew Sheppard
asheppard at houstoneng.com
Tue Oct 23 08:00:18 PDT 2012
The FPDF library used for printing in GeoMOOSE does not support UTF-8 by default. You might be able to use the tFPDF extension: http://fpdf.org/en/script/script92.php. You will need to make some modifications to print.php in order for FPDI to work with tFPDF: http://www.setasign.de/products/pdf-php-solutions/fpdi/demos/tfpdf-demo/
S. Andrew Sheppard
GIS/Web Developer
Houston Engineering, Inc.
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Efstathios Arapostathis
Sent: Sunday, October 21, 2012 11:16 AM
To: Jim Klassen
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] print issues in GM 2.4
Hi, I've read an old post that i Founf in the mailing list I commented line 151 in print_util.php :
# $url = $url . '&map_IMAGETYPE=print';
And now it works fine.
I'm now having one more problem. When I enter the map title I enter unicode characters (greek letters) but at the export pdf file instead of characters i'receiving" ?????????"
How can I change the character encoding for the print service to support unicode characters?
many thanks again
Stathis
On Sun, Oct 21, 2012 at 6:49 PM, Jim Klassen <klassen.js at gmail.com> wrote:
Is the temp directory configured in settings.ini present and writable?
On Oct 21, 2012, at 8:55 AM, Efstathios Arapostathis wrote:
> Hi guys,
> I'm facing problems with the printing service. When I press print the export result is an empty pdf file, without any map content in it.
> Any suggestions of what could be wrong?
> many thanks and regards,
> Stathis
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
