[Geomoose-users] Identify Tolerance
Clinton Olsen clintono at emery.utah.gov
Thu Oct 9 08:16:33 PDT 2014
I think my problem might be the projection.  I can see all my shapefiles
when I am using geomoose and they are placed where they need to be.  I am
using ESRI ARCMAP to reproject my shapefiles into the Web Mercator
projection (3857).  In the shapefile .prj file it shows
"PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere", in my mapfiles I have:
WEB
METADATA
'ows_title' 'Boulders'
'ows_srs' 'epsg:3857 epsg:900913 epsg:2281 epsg:3566'
'ows_enable_request' '*'
'ows_onlineresource' 'http://www.geomoose.org'
END
END
PROJECTION
'init=epsg:3857'
END
In my mapbook I have: <param name="projection">EPSG:3857</param>
and in my geomoose.html file I have: <script type="text/javascript"
src="projections/EPSG3857.js"></script>.  Is there anything I am missing?
What do other people use to reproject their shapefiles?
On Wed, Oct 8, 2014 at 11:07 AM, Clinton Olsen <clintono at emery.utah.gov>
wrote:
> Yes, I am still unable to successfully identify lines and points.  I had
> to step away from it for a little bit for my head to clear.  And I am
> willing to try any suggestions.
> On Wed, Oct 8, 2014 at 7:27 AM, Dan Little <theduckylittle at gmail.com>
> wrote:
>> Clinton, is this still a problem?
>> On Fri, Sep 19, 2014 at 10:51 AM, Clinton Olsen <clintono at emery.utah.gov>
>> wrote:
>> > Sorry about that.  Try this one:
>> > You can look at my map at:
>> http://168.179.236.3/geomoose2/geomoose.html.
>> > On Fri, Sep 19, 2014 at 8:48 AM, Brent Fraser <bfraser at geoanalytic.com>
>> > wrote:
>> >> Your site times out,
>> >> Best Regards,
>> >> Brent Fraser
>> http://168.179.236.58/geomoose2/geomoose.html.
>> >> The layer I am having trouble with is the boulder layer under the
>> testing
>> >> folder on the legend.  The only layers I have been able to get
>> identify to
>> >> work on is the parcel and NRCS layer.  I am trying to figure out how to
>> >> identify points and line layers on the map before I create more maps.
>> >> This is what I get when I try to identify the boulder layer, using the
>> f12
>> >> debug mode in chrome, with network traffic capturing enabled.
>> >> Remote Address:
>> >> 168.179.236.58:80
>> >> Request URL:
>> >> http://168.179.236.58/geomoose2/php/identify.php
>> >> Request Method:
>> >> POST
>> >> Status Code:
>> >> 200 OK
>> >> Request Headersview source
>> >> Accept:
>> >> Accept-Encoding:
>> >> gzip,deflate
>> >> Accept-Language:
>> >> en-US,en;q=0.8
>> >> Connection:
>> >> keep-alive
>> >> Content-Length:
>> >> 211
>> >> Content-Type:
>> >> application/x-www-form-urlencoded
>> >> Host:
>> >> 168.179.236.58
>> >> Origin:
>> >> Referer:
>> >> User-Agent:
>> >> Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like
>> Gecko)
>> >> Chrome/37.0.2062.120 Safari/537.36
>> >> X-Requested-With:
>> >> XMLHttpRequest
>> >> Form Dataview sourceview URL encoded
>> >> layers:
>> blank%3Ablank/blank%3AEMERY_BOULDERS%3AEMERY_BOULDERS/EMERY_BOULDERS%3Asketch
>> >> projection:
>> >> EPSG%3A3857
>> >> shape:
>> >> POINT%28-12374046.690745%204790938.2334565%29
>> >> dojo.preventCache:
>> >> 1411078405554
>> >> Response Headersview source
>> >> Connection:
>> >> Keep-Alive
>> >> Content-Type:
>> >> application/xml
>> >> Date:
>> >> Thu, 18 Sep 2014 22:13:34 GMT
>> >> Keep-Alive:
>> >> timeout=5, max=100
>> >> Server:
>> >> Apache/2.2.22 (Win32)
>> >> Transfer-Encoding:
>> >> chunked
>> >> X-Powered-By:
>> >> PHP/5.4.3
>> >> Response Body -
>> >> <results><script> GeoMOOSE.clearLayerParameters('highlight');
>> GeoMOOSE.turnLayerOff('highlight/highlight');</script><html><![CDATA[<!--
>> >> MapServer Template -->
>> >> Detailed information for the area you clicked on the map...
>> >> <table border="0">
>> >> <tr>
>> >> <td colspan="2"><b><u>Ground Coordinates</u></b>
>> >> <br>
>> >> <b>X: </b>-12374046.690745
>> >> <br>
>> >> <b>Y: </b>4790938.2334565</td>
>> >> </tr>
>> >> <tr>
>> >> <td> </td>
>> >> <td> </td>
>> >> </tr>
>> >> </table>
>> >> <table border="0" cellpadding="1" cellspacing="2">
>> >> ]]></html><footer><![CDATA[<b>Disclaimer: This information is being
>> >> distributed as demonstation data only.  You should not use the data
>> for any
>> >> other purposes.</b>
>> >> ]]></footer></results>
>> >> On Mon, Sep 8, 2014 at 11:51 AM, Clinton Olsen <
>> >>> http://168.179.236.58/geomoose2/geomoose.html.  The layer I am having
>> >>> trouble with is under the testing folder on the legend.  The only
>> layers I
>> >>> have been able to get identify to work is the parcel and NRCS layer.
>> I am
>> >>> using the boulder layer on the map to try and get it working before I
>> move
>> >>> it to one of my other maps.  Let me know if you want to look at
>> anything
>> >>> else.
>> >>> f12 debug mode in IE, with network traffic capturing enabled.
>> >>> Request Body-
>> layers=blank%253Ablank%2Fblank%253AEMERY_BORDER%253AEMERY_BORDER%2FEMERY_BORDER%253AEMERY_BOULDERS%253AEMERY_BOULDERS%2FEMERY_BOULDERS%253Asketch&projection=EPSG%253A3857&shape=POINT%2528-12376561.885991%25204763185.2284383%2529&dojo.preventCache=1410196885123
>> >>> Response Body -
>> >>> No data to view
>> >>> Clinton Olsen
>> >>> EMERY COUNTY
>> >>> IS/GIS Technician
>> >>> 435-381-3592
>> >> *Please note my email address has changed to clintono at emery.utah.gov.
>> >> Please update your records.  Thanks.
>> >> Clinton Olsen
>> >> EMERY COUNTY
>> >> IS/GIS Technician
>> >> 435-381-3592
>> > Clinton Olsen
>> > EMERY COUNTY
>> > IS/GIS Technician
>> > 435-381-3592
>> > _______________________________________________
>> > Geomoose-users mailing list
>> > Geomoose-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
> Clinton Olsen
> *EMERY COUNTY*
> IS/GIS Technician
> 435-381-3592
Clinton Olsen
*EMERY COUNTY*
IS/GIS Technician
435-381-3592
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20141009/4cf3a50e/attachment.html>
More information about the Geomoose-users mailing list
