[Geomoose-users] Identify Tolerance
Dan Little
theduckylittle at gmail.com
Thu Oct 9 08:56:13 PDT 2014
You're going to hate me for this but mine seems to just be working.
I've attached a minimalistic example. The points will all be in
Minnesota.
Maybe try taking this and building off of it. The shapefile is stored
in UTM15N.
On Thu, Oct 9, 2014 at 10:16 AM, Clinton Olsen <clintono at emery.utah.gov> wrote:
> I think my problem might be the projection. I can see all my shapefiles
> when I am using geomoose and they are placed where they need to be. I am
> using ESRI ARCMAP to reproject my shapefiles into the Web Mercator
> projection (3857). In the shapefile .prj file it shows
> "PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere", in my mapfiles I have:
> WEB
> METADATA
> 'ows_title' 'Boulders'
> 'ows_srs' 'epsg:3857 epsg:900913 epsg:2281 epsg:3566'
> 'ows_enable_request' '*'
> 'ows_onlineresource' 'http://www.geomoose.org'
> END
> END
> PROJECTION
> 'init=epsg:3857'
> END
> In my mapbook I have: <param name="projection">EPSG:3857</param>
> and in my geomoose.html file I have: <script type="text/javascript"
> src="projections/EPSG3857.js"></script>. Is there anything I am missing?
> What do other people use to reproject their shapefiles?
> On Wed, Oct 8, 2014 at 11:07 AM, Clinton Olsen <clintono at emery.utah.gov>
> wrote:
>> Yes, I am still unable to successfully identify lines and points. I had
>> to step away from it for a little bit for my head to clear. And I am
>> willing to try any suggestions.
>> On Wed, Oct 8, 2014 at 7:27 AM, Dan Little <theduckylittle at gmail.com>
>> wrote:
>>> Clinton, is this still a problem?
>>> On Fri, Sep 19, 2014 at 10:51 AM, Clinton Olsen <clintono at emery.utah.gov>
>>> wrote:
>>> > Sorry about that. Try this one:
>>> > You can look at my map at:
>>> > http://168.179.236.3/geomoose2/geomoose.html.
>>> > On Fri, Sep 19, 2014 at 8:48 AM, Brent Fraser <bfraser at geoanalytic.com>
>>> > wrote:
>>> >> Your site times out,
>>> >> Best Regards,
>>> >> Brent Fraser
>>> >> http://168.179.236.58/geomoose2/geomoose.html.
>>> >> The layer I am having trouble with is the boulder layer under the
>>> >> testing
>>> >> folder on the legend. The only layers I have been able to get
>>> >> identify to
>>> >> work on is the parcel and NRCS layer. I am trying to figure out how
>>> >> to
>>> >> identify points and line layers on the map before I create more maps.
>>> >> This is what I get when I try to identify the boulder layer, using the
>>> >> f12
>>> >> debug mode in chrome, with network traffic capturing enabled.
>>> >> Remote Address:
>>> >> 168.179.236.58:80
>>> >> Request URL:
>>> >> http://168.179.236.58/geomoose2/php/identify.php
>>> >> Request Method:
>>> >> POST
>>> >> Status Code:
>>> >> 200 OK
>>> >> Request Headersview source
>>> >> Accept:
>>> >> Accept-Encoding:
>>> >> gzip,deflate
>>> >> Accept-Language:
>>> >> en-US,en;q=0.8
>>> >> Connection:
>>> >> keep-alive
>>> >> Content-Length:
>>> >> 211
>>> >> Content-Type:
>>> >> application/x-www-form-urlencoded
>>> >> Host:
>>> >> 168.179.236.58
>>> >> Origin:
>>> >> Referer:
>>> >> User-Agent:
>>> >> Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like
>>> >> Gecko)
>>> >> Chrome/37.0.2062.120 Safari/537.36
>>> >> X-Requested-With:
>>> >> XMLHttpRequest
>>> >> Form Dataview sourceview URL encoded
>>> >> layers:
>>> >> blank%3Ablank/blank%3AEMERY_BOULDERS%3AEMERY_BOULDERS/EMERY_BOULDERS%3Asketch
>>> >> projection:
>>> >> EPSG%3A3857
>>> >> shape:
>>> >> POINT%28-12374046.690745%204790938.2334565%29
>>> >> dojo.preventCache:
>>> >> 1411078405554
>>> >> Response Headersview source
>>> >> Connection:
>>> >> Keep-Alive
>>> >> Content-Type:
>>> >> application/xml
>>> >> Date:
>>> >> Thu, 18 Sep 2014 22:13:34 GMT
>>> >> Keep-Alive:
>>> >> timeout=5, max=100
>>> >> Server:
>>> >> Apache/2.2.22 (Win32)
>>> >> Transfer-Encoding:
>>> >> chunked
>>> >> X-Powered-By:
>>> >> PHP/5.4.3
>>> >> Response Body -
>>> >> <results><script> GeoMOOSE.clearLayerParameters('highlight');
>>> >> GeoMOOSE.turnLayerOff('highlight/highlight');</script><html><![CDATA[<!--
>>> >> MapServer Template -->
>>> >> Detailed information for the area you clicked on the map...
>>> >> <table border="0">
>>> >> <tr>
>>> >> <td colspan="2"><b><u>Ground Coordinates</u></b>
>>> >> <br>
>>> >> <b>X: </b>-12374046.690745
>>> >> <br>
>>> >> <b>Y: </b>4790938.2334565</td>
>>> >> </tr>
>>> >> <tr>
>>> >> <td> </td>
>>> >> <td> </td>
>>> >> </tr>
>>> >> </table>
>>> >> <table border="0" cellpadding="1" cellspacing="2">
>>> >> ]]></html><footer><![CDATA[<b>Disclaimer: This information is being
>>> >> distributed as demonstation data only. You should not use the data
>>> >> for any
>>> >> other purposes.</b>
>>> >> ]]></footer></results>
>>> >> On Mon, Sep 8, 2014 at 11:51 AM, Clinton Olsen
>>> >>> http://168.179.236.58/geomoose2/geomoose.html. The layer I am having
>>> >>> trouble with is under the testing folder on the legend. The only
>>> >>> layers I
>>> >>> have been able to get identify to work is the parcel and NRCS layer.
>>> >>> I am
>>> >>> using the boulder layer on the map to try and get it working before I
>>> >>> move
>>> >>> it to one of my other maps. Let me know if you want to look at
>>> >>> anything
>>> >>> else.
>>> >>> the
>>> >>> f12 debug mode in IE, with network traffic capturing enabled.
>>> >>> Request Body-
>>> >>> layers=blank%253Ablank%2Fblank%253AEMERY_BORDER%253AEMERY_BORDER%2FEMERY_BORDER%253AEMERY_BOULDERS%253AEMERY_BOULDERS%2FEMERY_BOULDERS%253Asketch&projection=EPSG%253A3857&shape=POINT%2528-12376561.885991%25204763185.2284383%2529&dojo.preventCache=1410196885123
>>> >>> Response Body -
>>> >>> No data to view
>>> >>> Clinton Olsen
>>> >>> EMERY COUNTY
>>> >>> IS/GIS Technician
>>> >>> 435-381-3592
>>> >> *Please note my email address has changed to clintono at emery.utah.gov.
>>> >> Please update your records. Thanks.
>>> >> Clinton Olsen
>>> >> EMERY COUNTY
>>> >> IS/GIS Technician
>>> >> 435-381-3592
>>> > Clinton Olsen
>>> > EMERY COUNTY
>>> > IS/GIS Technician
>>> > 435-381-3592
>>> > _______________________________________________
>>> > Geomoose-users mailing list
>>> > Geomoose-users at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Clinton Olsen
>> EMERY COUNTY
>> IS/GIS Technician
>> 435-381-3592
> Clinton Olsen
> EMERY COUNTY
> IS/GIS Technician
> 435-381-3592
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20141009/3a276208/attachment-0001.zip>
More information about the Geomoose-users
