[Geomoose-users] Identify Tolerance
Bistrais, Bob Bob.Bistrais at maine.gov
Thu Oct 9 09:02:57 PDT 2014
If you haven't tried this already, try using the Box option with the identify tool, see if you can at least Identify those layers with the box option.  At least that way you'll know if those layers can be identified at all.
Also (and maybe I missed that part of the discussion) - have you adjusted the search tolerances?
-----Original Message-----
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Dan Little
Sent: Thursday, October 09, 2014 11:56 AM
To: Clinton Olsen
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Identify Tolerance
You're going to hate me for this but mine seems to just be working.
I've attached a minimalistic example.  The points will all be in Minnesota.
Maybe try taking this and building off of it.  The shapefile is stored in UTM15N.
On Thu, Oct 9, 2014 at 10:16 AM, Clinton Olsen <clintono at emery.utah.gov> wrote:
> I think my problem might be the projection.  I can see all my
> shapefiles when I am using geomoose and they are placed where they
> need to be.  I am using ESRI ARCMAP to reproject my shapefiles into
> the Web Mercator projection (3857).  In the shapefile .prj file it
> shows "PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere", in my mapfiles I have:
> WEB
> METADATA
> 'ows_title' 'Boulders'
> 'ows_srs' 'epsg:3857 epsg:900913 epsg:2281 epsg:3566'
> 'ows_enable_request' '*'
> 'ows_onlineresource' 'http://www.geomoose.org'
> END
> END
> PROJECTION
> 'init=epsg:3857'
> END
> In my mapbook I have: <param name="projection">EPSG:3857</param>
> and in my geomoose.html file I have: <script type="text/javascript"
> src="projections/EPSG3857.js"></script>.  Is there anything I am missing?
> What do other people use to reproject their shapefiles?
> On Wed, Oct 8, 2014 at 11:07 AM, Clinton Olsen
> wrote:
>> Yes, I am still unable to successfully identify lines and points.  I
>> had to step away from it for a little bit for my head to clear.  And
>> I am willing to try any suggestions.
>> On Wed, Oct 8, 2014 at 7:27 AM, Dan Little <theduckylittle at gmail.com>
>> wrote:
>>> Clinton, is this still a problem?
>>> On Fri, Sep 19, 2014 at 10:51 AM, Clinton Olsen
>>> wrote:
>>> > Sorry about that.  Try this one:
>>> > You can look at my map at:
>>> > http://168.179.236.3/geomoose2/geomoose.html.
>>> > On Fri, Sep 19, 2014 at 8:48 AM, Brent Fraser
>>> > <bfraser at geoanalytic.com>
>>> > wrote:
>>> >> Your site times out,
>>> >> Best Regards,
>>> >> Brent Fraser
>>> >> http://168.179.236.58/geomoose2/geomoose.html.
>>> >> The layer I am having trouble with is the boulder layer under the
>>> >> testing folder on the legend.  The only layers I have been able
>>> >> to get identify to work on is the parcel and NRCS layer.  I am
>>> >> trying to figure out how to identify points and line layers on
>>> >> the map before I create more maps.
>>> >> This is what I get when I try to identify the boulder layer,
>>> >> using the
>>> >> f12
>>> >> debug mode in chrome, with network traffic capturing enabled.
>>> >> Remote Address:
>>> >> 168.179.236.58:80
>>> >> Request URL:
>>> >> http://168.179.236.58/geomoose2/php/identify.php
>>> >> Request Method:
>>> >> POST
>>> >> Status Code:
>>> >> 200 OK
>>> >> Request Headersview source
>>> >> Accept:
>>> >> Accept-Encoding:
>>> >> gzip,deflate
>>> >> Accept-Language:
>>> >> en-US,en;q=0.8
>>> >> Connection:
>>> >> keep-alive
>>> >> Content-Length:
>>> >> 211
>>> >> Content-Type:
>>> >> application/x-www-form-urlencoded
>>> >> Host:
>>> >> 168.179.236.58
>>> >> Origin:
>>> >> Referer:
>>> >> User-Agent:
>>> >> Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML,
>>> >> like
>>> >> Gecko)
>>> >> Chrome/37.0.2062.120 Safari/537.36
>>> >> X-Requested-With:
>>> >> XMLHttpRequest
>>> >> Form Dataview sourceview URL encoded
>>> >> layers:
>>> >> blank%3Ablank/blank%3AEMERY_BOULDERS%3AEMERY_BOULDERS/EMERY_BOULD
>>> >> ERS%3Asketch
>>> >> projection:
>>> >> EPSG%3A3857
>>> >> shape:
>>> >> POINT%28-12374046.690745%204790938.2334565%29
>>> >> dojo.preventCache:
>>> >> 1411078405554
>>> >> Response Headersview source
>>> >> Connection:
>>> >> Keep-Alive
>>> >> Content-Type:
>>> >> application/xml
>>> >> Date:
>>> >> Thu, 18 Sep 2014 22:13:34 GMT
>>> >> Keep-Alive:
>>> >> timeout=5, max=100
>>> >> Server:
>>> >> Apache/2.2.22 (Win32)
>>> >> Transfer-Encoding:
>>> >> chunked
>>> >> X-Powered-By:
>>> >> PHP/5.4.3
>>> >> Response Body -
>>> >> <results><script> GeoMOOSE.clearLayerParameters('highlight');
>>> >> GeoMOOSE.turnLayerOff('highlight/highlight');</script><html><![CD
>>> >> ATA[<!--
>>> >> MapServer Template -->
>>> >> Detailed information for the area you clicked on the map...
>>> >> <table border="0">
>>> >> <tr>
>>> >> <td colspan="2"><b><u>Ground Coordinates</u></b> <br>
>>> >> <b>X: </b>-12374046.690745
>>> >> <br>
>>> >> <b>Y: </b>4790938.2334565</td>
>>> >> </tr>
>>> >> <tr>
>>> >> <td> </td>
>>> >> <td> </td>
>>> >> </tr>
>>> >> </table>
>>> >> <table border="0" cellpadding="1" cellspacing="2">
>>> >> ]]></html><footer><![CDATA[<b>Disclaimer: This information is
>>> >> being distributed as demonstation data only.  You should not use
>>> >> the data for any other purposes.</b> ]]></footer></results>
>>> >> On Mon, Sep 8, 2014 at 11:51 AM, Clinton Olsen
>>> >>> http://168.179.236.58/geomoose2/geomoose.html.  The layer I am
>>> >>> having trouble with is under the testing folder on the legend.
>>> >>> The only layers I have been able to get identify to work is the
>>> >>> I am
>>> >>> using the boulder layer on the map to try and get it working
>>> >>> before I move it to one of my other maps.  Let me know if you
>>> >>> want to look at anything else.
>>> >>> using the
>>> >>> f12 debug mode in IE, with network traffic capturing enabled.
>>> >>> Request Body-
>>> >>> layers=blank%253Ablank%2Fblank%253AEMERY_BORDER%253AEMERY_BORDER
>>> >>> %2FEMERY_BORDER%253AEMERY_BOULDERS%253AEMERY_BOULDERS%2FEMERY_BO
>>> >>> ULDERS%253Asketch&projection=EPSG%253A3857&shape=POINT%2528-1237
>>> >>> 6561.885991%25204763185.2284383%2529&dojo.preventCache=141019688
>>> >>> 5123
>>> >>> Response Body -
>>> >>> No data to view
>>> >>> Clinton Olsen
>>> >>> EMERY COUNTY
>>> >>> IS/GIS Technician
>>> >>> 435-381-3592
>>> >> *Please note my email address has changed to clintono at emery.utah.gov.
>>> >> Please update your records.  Thanks.
>>> >> Clinton Olsen
>>> >> EMERY COUNTY
>>> >> IS/GIS Technician
>>> >> 435-381-3592
>>> > Clinton Olsen
>>> > EMERY COUNTY
>>> > IS/GIS Technician
>>> > 435-381-3592
>>> > _______________________________________________
>>> > Geomoose-users mailing list
>>> > Geomoose-users at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Clinton Olsen
>> EMERY COUNTY
>> IS/GIS Technician
>> 435-381-3592
> Clinton Olsen
> EMERY COUNTY
> IS/GIS Technician
> 435-381-3592
More information about the Geomoose-users mailing list
